Monitor 70 Stands
Does anyone know of any stands that will work with Monitor 70s? I'm using M70s as my surround backs and need to raise them a few feet so they aren't being blocked by my back row recliners.
Post edited by fused on
Keep in mind that you want to keep your tweeters at ear level as much as possible. Maybe just build up with an eight inch wood riser that you make? Good luck,DMIT Magnum MH-750, Monster HTS 5100MKII, Sony 77" Class - A80CJ Series - 4K UHD OLED,PS4, Def Tech 15” sub,LSIM 706c, Sunfire Signature Grand 425 x 4,Parasound hca 120, LSiM 702 x 4, Oppo 103D, SDA SRS 1.2, Pioneer Elite SC63 , Pioneer Elite BDP-05 “Why did you get married if you wanted big speakers?”
A few feet?
Honestly, I would get rid of them and use the money to buy some bookshelves that you can easily mount on the wall. -
you want to raise your towers above your recliner? you would need to go 4-5 feet just to give all your drivers exposure. I doubt you'll find commercially available stands. Like dabutch says you will have to custom make something or do a search for stands on here, I think I saw some sturdy ones here http://www.audioconnect.com/target-mr-series.jpgSamsung pn64f8500
Sonus faber venere 2.5
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Audioquest cables asst
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3
