LSi-15 partial meltdown??
Resistor issue with the LSi15 (and carver by chance)
Yep, that was me, I fried them real good... I later bought a set that had been modded by our Ben and they were awesome!! I later sold them , but I still have the original set, hardly ever hook them up though since I got the 1.2TL's. They do sound good though!!Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Maximus666,
No, you misunderstood my point. I didn't say that it wasn't rated at 700wpc. I said that I doubted it was putting that out at the time. Hell, at normal listening level's you're only using a few wpc. It's the transients that will require larger amounts of power.
You'll get argument from me on that one.So definitely something amiss there.I like to hedge my bets with larger guage copper (fine) stranded, however, rather than spend hundreds of dollars on cable with special physics.
Increasing the gauge of chassis wire doesn't guarantee a positive result and in fact, can lead to a negative result.Political Correctness'.........defined
President of Club Polk -
Assuming it is the one in the tweeter circuit - it is a 2ohm - 5 watt resistor.
I would replace it with a 2ohm - 12watt mills resistor. (you can get them a bunch of places including sonicraft and parts express)
Just so you know - there are 3 - 2ohm resistors (1 for the tweeter and 1 for each mid-woofer) and 1 - 3.5 ohm resistor for the 8" woofer per speaker. While you are in there, you might as well replace them all - after all, their cheap.....
Michael
Ah, thank you Michael. Excellent advice as well.Political Correctness'.........defined
Maximus666,
Hard Rock at high volume... I had to be pushing no less than 450 to 500 constantly. I had it cranked WAY up while I was working in the garage.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Remember - the speaker is only rated for 350watts continuous. It can take WAY MORE than that (if its clean) on peaks - but I would not recommend exceeding the continuous rating for more than a few seconds.
Be happy the damage (if indeed there really was any) was as minimal as it appears. If you want loud garage speakers - Cerwin Vega or Klipsh will work well. Keep listening at those volumes and you will not be able to hear the difference between those and Polk anyway.....
I agree with you Xo are mainly resistors, caps and coils and they are not as sentive as transistors but values are decide by engineers for a reason as they affect each other. Now, as an example wouldn't you prefer replacing a cheap ceramic or a tweeter? You also have a valid point about weakess link (meaning under evaluation during engineering process). Was there any mod recommendated by Polk in reference the increased in wattage? Going from 5 watts to 12 watts is rather a drasting change IMHO???May be true if there are transistors in the circuit, but in these crossovers, all there is, is resistors, caps and coils. The 5 watt resistor (specifically in the tweeter) seems to be the weak link. I have not heard of anyone doing an upgrade (or mod) to the resistors in a crossover that did not use the same values of a higher wattage.
In almost all cases - it seems to be the 12 watt mills is the weapon of choice.
To each their own though.
Michael
Cheers!
TKDARE TO SOAR:
Not by Polk, but when I called SonicCraft to ask about the crossover upgrade, they recommended the 12 watt resistor (Mills does also make a 5 watt one) as they felt it sounded better in a crossover circuit. Also when looking at crossover upgrades here on Club Polk - 12 watt mills seems to be the overwhelming choice for resistor swaps.
That is what I and others have used with good sucess. Not saying you are incorrect, just that was why I chose to use 12 watt mills in my crossover upgrades. I know I have been happy with the sound, thats for sure.
Yep, you might not need thoses speakers any longer and simply listen to your favorite music through vibrationRemember - the speaker is only rated for 350watts continuous. It can take WAY MORE than that (if its clean) on peaks - but I would not recommend exceeding the continuous rating for more than a few seconds.
Michael
DARE TO SOAR:
Thanks for the answer and explanations, no right or wrong, just sharing opinions but one thing for sure nothing beats hands on experience which you do have. Thanks again...Not by Polk, but when I called SonicCraft to ask about the crossover upgrade, they recommended the 12 watt resistor (Mills does also make a 5 watt one) as they felt it sounded better in a crossover circuit. Also when looking at crossover upgrades here on Club Polk - 12 watt mills seems to be the overwhelming choice for resistor swaps.
MichaelDARE TO SOAR:
Michael
LOL....
My speakers are in my living room and I was working in the garage, about 60 feet and three walls away. My hearing was never in danger.:p I will be working on a garage rig for future use. I have a nice BeoCenter that will be hung on the wall and a cd player, but I have not taken the time to set them up.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
The use of a 12 watt in place of the 5 watt is not going to affect any other part of the crossover in a negative way. It will allow for higher power handling, which is a good thing in the case of the LSi's as it seems the 5 watt value is a little too low for folks driving them with high powered amps.Political Correctness'.........defined
Resistors, higher wattage is ok, Capacitors, higher voltage is ok also. Just don't ever go lower.
I've seen a few cases of polyfill melting to crossover boards. Try pushing it away from the crossover to give it some room to breath."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Nooshinjohn,
Send the crossovers to us here in Baltimore and address them to my attention along with the serial numbers of both speakers and I will send you replacement crossovers at no charge.
Thanks,
Kim
Thanks Kim... but these girls are out of warranty by along shot... and I have no doubt the cause of their needing to be fixed is that they were being abused. If the offer still stands, they will be on the way.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
My offer still stands. I will like to see how bad the meltdown actually was.
I want to pass these on to the guys in engineering and Q/A.
Do you need our address in Baltimore?
Send me an email with your information and serial numbers to: KJasper@polkaudio.com.
Thanks Kim... I sent you a PM asking for the address.
POLK CS IS THE BEST!!!:D:DThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
nooshinjohn wrote: »Thanks Kim... I sent you a PM asking for the address.
This is why I will ALWAYS have Polk speakers!!! CS like this is just first rate.
Polk Audio ROCKS!!!:)Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Wow that's just awesome.Panny 55-st30 plasma
Pioneer vsx-1121
Parasound 2100 pre
b&k tx4430 amp
Oppo bdp-83
Monster HTS 3500
polk TSi500s Vr3 Fortress modded
polk CS20 center channel Vr3 Castle modded
polk Owm 3 surrounds
polk PSW505 -
Outstanding! Not only providing for the replacement but taking action to problem solving, OUTSTANDING !!!!My offer still stands. I will like to see how bad the meltdown actually was.
I want to pass these on to the guys in engineering and Q/A.Do you need our address in Baltimore?
Send me an email with your information and serial numbers to: KJasper@polkaudio.com.DARE TO SOAR:
I just got an email from Kim... he has the replacements shipping today!...
I have for some time been contemplating Maggies in my rig. I will be sticking with Polk and wait and see what the new LSi's are all about. If they can image like the LSi's and present the soundstage and authority of my SDA's, I will take a pair.(or two):DThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Kim's the man...!
Post a photo of your new 'stang? -
John, if it was louder than the time i heard your LSi15s, you've officially gone off the deep end. Just sayin'.
concealer404 wrote: »...you've officially gone off the deep end. Just sayin'.
Right behind ya Bro!!!:D;)The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
It IS way nicer down here, i'll tell you that much.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
Then he must have been under your wings and you trained him wellKenneth Swauger wrote: »Kim's the man...!
Afterall, you left some big shoes to be filled!!!DARE TO SOAR:
It doesn't take much to completely damage electronics since they have such a low tolerance for temperature changes. I'd the think LSi's would shut down before damage was done.~Dan
Projector: Epson 705HD on 106" DaLite
TV: Samsung 50" Plasma PN50B550
Receiver: Onkyo 607
Fronts: Polk 1000i
Center: Polk Csi40
Rears: Polk Fxi30
Sub: Velodyne Minivee 10
PS3 and Xbox -
I assumed that too. Funny thing now is that my amp is running hotter than normal now with my SDA's back in the loop. I wonder if something got cooked there too.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Most speakers, being passive, only shutdown when they break.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
If you need a second opinion on that amp...send it to me for a few years and I'll let you know if I think there is any damage:)
cincycat13 wrote: »If you need a second opinion on that amp...send it to me for a few years and I'll let you know if I think there is any damage:)
Ummmm yeah... that's my first choice.:D:D;)The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
____________________
Pool: Atrium 60's/45's
