Snagged a PSW505 today
Dobermann
Been in the market for a new sub for a little while and the Newegg price was just too good to pass up.
The 505 is meant to replace a PSW10 that I've had for several years and have never really been satisfied with. But I'm wondering if the PSW10 can be used as a second sub....it can't go very low or loud, but maybe if I keep it within its limitations?
Anybody ever done anything like this? I've heard that running two subs can be difficult, but I don't really know about phases or standing waves or any of that stuff.
Setup is a Denon AVR-591 with Polk M20/R15/CSM.
Post edited by Dobermann on
You could put the psw10 in the back of the room gained down to not kill it but it'd help eliminate any dead spots possibly. Play with it. You might find a great spot that is a nice add on. Or you'll see it does nothing beneficial and you end up not using it. Either way, you'll at least know if it wouldve helped and gave you something to play with.Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
tough to do so esp. if you have two subs of completely different frequency responses and outputs. even if you try to gain match the two according to all the documented mechanisms (turn one sub on and use your spl meter to set, then the other one etc), it would cause the weaker sub to in effect be your weakest link since in order to match the more powerful sub, the weaker one would be distorting or bottoming out for the same SPL... if you went the other way and tried to downscale your bigger sub to the weaker one's spl, then you are not utilizing the full benefits of the big sub...
having said all that, no harm in trying it out like Toxis suggested. Each room has its own dead spots and a little bit of boost of the little sub may even out your overall frequency response at a given spl over a wider range which is what you are aiming for.Fronts: Wharfedale diamond 9.6
Sub: Wharfedale sw250
Rears: Wharfedale diamond 9.1
Center: Paradigm cc-350
Pre-amp: Oppo dv981hd
Amp for fronts: Parasound hca-1500a
Amp for rears: Adcom gfa-5400
Amp for center: Marantz MA500 monoblock
Polk multimedia speakers for PC setup -
look at the post started by "Arkive" in this forum... or search for multiple sub calibration... theres a ton of information out there..Fronts: Wharfedale diamond 9.6
I second the notion of using the psw10 as a sort of dead spot reviver....I know that an area in my living room that is practically bass-less do to a massive dead-spot..been meaning to put a smaller sub there to just sort of shadow my bigger psw505....Receiver
Harman Kardon HK 3490
Speakers
Polk Audio Monitor 50s
Subwoofer
Klipsch KSW-100
Cables
AudioQuest Rocket 33s 10ft
AudioQuest Optilink1 2m
AudioQuest Alpha-Snake 25ft Interconnect
AudioQuest HDMI-1 2m
Alienware X51 R2
PS4
Samsung Smart TV 40" 1080p 3D -
Perfect, there are several PSW303's listed on the bay right now. I picked up one last week for $81 and $12 shipping, it is supposed to arrive today. I am sure that one of the ones listed will also end under $100.
I haven't noticed any dead spots with my 505. I am sure that I will make one up
or use the sub in my bedroom. System:
Samsung LN46C630
Receiver: Yamaha RX-V1
DVD/Blu: Denon 2910/Playstation 3
Front mains: RT16
Front presence: F/X 500i
Center: CS400
Rear surrounds: RT1000p
Rear center: RT7
Subwoofer: PSW505 X 2
Marantz 2252B
Technics SL-Q2 turntable
Kef Q50 -
Tried the sub with some music tonight and was impressed, even in the 2.1 setup. At first I thought there was something wrong because I was getting very little output but then I found the crossover setup in my new Denon receiver and BAM there it was.
Started off with Between the Buried and Me's The Great Misdirect, lots of kick drum in this album. Felt a little better about things, so I turned the cross over up to 120 and then it really started to shine. Then I put on Outkast's debut album, then some Jay-Z, and ended up with Opeth's last album.
This thing is great, for real. I haven't tried it with movies yet, where I imagine it'll show whatever weaknesses it has, but so far I am ecstatic. I can't imagine what it's going to sound like with a few more hours on it. -
Congrats on your new purchase...that's a nice sub for your purposes.
I also second Toxis's suggestions above.
Enjoy!
