Seal Back Speakers in Ranger PICS
p0wd3rmnky
I think I figured out why my back speakers sound terrible and have NO bass. They are basically free air. How do you recommend I seal them into the enclosure? I know someone out there has done this before. Thank you.
Post edited by p0wd3rmnky on
can you take the back panel off? if so i would think to make a small lil enclosure around the speakers.mole'
When you say back panel, what do you mean the silver metal bracket that goes in between the speaker and the white metal of the truck?
You may want to take a look at getting two baffels
http://www.crutchfield.com/S-N3c1AGX59i4/g_762/Foam-Speaker-Baffles.html
They are foam, and yes I currently use them, and it works fine for me. Plus I used them more to protect my front speakers from getting wet when I rolled down the window etc, since the DB speakers did not have a built in baffel. Or the other option is to build your own fiber glass enclosure to fit that hole, and place the speaker in the enclosure. Hope this helps.
Thanks.2006 Prerunner Access Cab
5 Speed 4 cycl 2wd
Audio:
Pioneer P860 Head Unit
Polk Audio MM6501
Alpine PDX F-6
Two SR124(SVC)
Alpine PDX M12
Kinetik HC2000 battery and Sleeve
200 Amp Mean Green High Output Alternator
Need a DJ, photobooth, or both for rent?
http://photoboothdallas.org -
Most car speakers are designed to run free air. The speakers in your doors are free air. The problem with the rear speakers in that truck is if you take a close look at the mount it does a terrible job of isolating the front of the speaker from the back therefore you get cancellations. Build you a new baffle so that the front is sealed from the back and you will notice a difference. Also sealing the cavity with dynamat or similar product will help. Don't waste your time with foam baffles or building and enclosure because it will not do much for you.
Installer4life wrote: »Most car speakers are designed to run free air. The speakers in your doors are free air. The problem with the rear speakers in that truck is if you take a close look at the mount it does a terrible job of isolating the front of the speaker from the back therefore you get cancellations. Build you a new baffle so that the front is sealed from the back and you will notice a difference. Also sealing the cavity with dynamat or similar product will help. Don't waste your time with foam baffles or building and enclosure because it will not do much for you.
Oh, well I retract my previous post, please disregard. My bad thought it was a good idea. Sorry about that.
Also installer I might have to ask you about your statement sometime to get more info, but not at this time that is for another time, and thanks for the correction.
5 Speed 4 cycl 2wd
Audio:
Polk Audio MM6501
Alpine PDX F-6
Two SR124(SVC)
Alpine PDX M12
They are 5x7's. Any ideas on what material to use to seal it or how to build a new baffle? I thought of making a MDF spacer, but I don't think the speaker covers would fit. Thanks
Take the metal bracket off and make one out of 1/2" MDF. You can get a small piece at The Home Depot or Lowes. Cut it so it is large enough to to cover the existing hole in the truck. Cut a new 5X7 hole in the wood. You may have to trim some of the metal because the hole in the truck may not be large enough. Seal it with some foam insulation tape and you will be good to go...
Thank you!
posts 13-16 reported (from soon to be banned thalgetycle)VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels
