I NEED EXACT measurements for a dual seal box for SR124DVC subs
Please I need,want some help with building a box for these subs...I really DON'T want to blow these.I read a lot people having problems with the lead or the voice coil going out.So Any help would be nice .
Post edited by Marvelous Marv on
http://www.polkaudio.com/caraudio/subbox/subbox_plan.php?id=96&mesurements=standard
Driver Properties
Name SR124 (4 ohm)
Diameter 12 in.
No. of Drivers 1
Fs 29
Qms 6.9
Vas 53 Liters
Xmax 16.25 mm / 0.64 in
Sd 499 sq. cm / 77.35 sq. in
Qes 0.58
Z 4 ohm
Pe 1400
Box Properties
Type Single Sealed
Shape square
Enclosure details 1.20 cu. ft. (33.98 liters)
Overall External Dimensions
Width 16" (40.64cm)
Height 18" (45.72cm)
Depth 11-1/2" (29.21cm)
http://www.polkaudio.com/caraudio/subbox/subbox_plan.php?id=102&mesurements=standard
Driver Properties
Name SR124 (4 ohm)
Diameter 12 in.
No. of Drivers 2
Fs 29
Qms 6.9
Vas 53 Liters
Qes 0.58
Z 4 ohm
Pe 1400
Box Properties
Type Dual Ported
Shape Square
Comment 1 Vent (2.5 inches high x 13.5 inches wide x 15 inches long)
Enclosure details 3.28 cu. ft. (92.82 liters)
Width 36" (91.44cm)
Height 15" (38.10cm)
Depth 16" (40.64cm)
Sorry about that did not read main post. You wanted sealed. My bad.
5 Speed 4 cycl 2wd
Audio:
Pioneer P860 Head Unit
Polk Audio MM6501
Alpine PDX F-6
Two SR124(SVC)
Alpine PDX M12
Kinetik HC2000 battery and Sleeve
200 Amp Mean Green High Output Alternator
Need a DJ, photobooth, or both for rent?
http://photoboothdallas.org
Start with how much room you can afford to take up with the box, and go from there. In fact if you could supply that... That would be helpful.
5 Speed 4 cycl 2wd
Audio:
Polk Audio MM6501
Alpine PDX F-6
Two SR124(SVC)
Alpine PDX M12
As for you brutus amp, in fact if you wired the subs down to a 2 ohm load that would be just fine. It would be a little under power of the internal rms of the subs, but that should be fine. Now I dont know off hand if the subs can be wired down to 1 ohm (dont see why not), but if you can get it down to 1 ohm you would be prefectly fine, in fact that put about 1700 watts divided by 2 that is about 850 watts per sub. So, you might be just fine with the brutus. As for the Audioque 1200D you would be stepping down way down. Again it all comes down tuning of the amps freq, and the box.
5 Speed 4 cycl 2wd
Audio:
Polk Audio MM6501
Alpine PDX F-6
Two SR124(SVC)
Alpine PDX M12
http://www.the12volt.com/caraudio/boxcalcs.asp#rec
I would say that if you trunk is 3.5 Ft3, and you have two subs, and put them in a sealed box, (basically doubleing the space needed for one) 1.2 + 1.2 = 2.4 Ft3. So, this could be a good starting point. Also measure your trunk to the space that is best for you as well. So, lets say you only want to take up about half the trunk space, then you would measure HxWxL, and account for wood thickness as well. The website that I have listed here for you will let you play with number, speaker wiring, and final load etc etc. I know that there is another website that does this as well, but only sub box related. I can find it right now, but if I do find it, I will post here for you. You can also use the T/S parameters as well on this site.
This will also show how if you wire your subs in either parallel, or series what the final load will be that the amp should see as well. Hope this helps.
Thanks.
5 Speed 4 cycl 2wd
Audio:
Polk Audio MM6501
Alpine PDX F-6
Two SR124(SVC)
Alpine PDX M12
Pioneer DEX-P99RS, IPOD Touch 64gb, Rockford Fosgate T1000-4, T600-2 & T1500-1bd CP
Polk Audio SR speakers, 6.5's, 5.25's, SR tweets and 2 SR124-DVC subs in 1.57cu ft sealed enclosures
