SDA 1-C's: twin blade or pin/blade cable ?
mhw58
mhw58 Posts: 361
edited July 2010 in 2 Channel Audio
Do the SDA 1-C's use the blade/blade interconnect
cable of the pin/blade one?
THanks, Mike
Fronts: SDA1C's
Rears: SDA2's
Center:CS400i
Sub: PSW505
  • nascarmann
    nascarmann Posts: 1,464
    edited August 2002
    Only the pin/blade....
    Oh, the bottle has been to me, my closes friend, my worse enemy!
  • mhw58
    mhw58 Posts: 361
    edited August 2002
    Nascarman,
    Are these pin/blade cables available anywhere? Polk
    still makes the twin blade but no the pin/blade.
    Mike
    Fronts: SDA1C's
    Rears: SDA2's
    Center:CS400i
    Sub: PSW505
  • hoosier21
    hoosier21 Posts: 4,437
    edited August 2002
    Polk won't make them, you can make one, search the forum somebody had a diagram and posted it, it was easy take speaker wire RCA plug striped to just the pin and a spade terminal.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • har_navalta
    har_navalta Posts: 957
    edited September 2002
    Ok, here we go again...
    A recap of 'HOW TO' make your own Interconnect Cable 'Pin and Blade Connection' for SDA type speakers. Since then my SDA's
    still perfectly sounding awesome...
    http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=2872
    Enjoy reading...my diagram of HOW TO.
    Har
  • onearmrog
    onearmrog Posts: 16
    edited July 2010
    On the 1-C the cable is pin/spade, I need to make a cable, does it run pin to pin or pin to spade ?
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited July 2010
    FYI they made 1c's with pin/blade and blade/blade. I have a set of each if you're looking.
  • onearmrog
    Its been 6 years and just noticed your reply, can still use as cable
    pitdogg2 Posts: 27,918
    It's a safe bet it's Long gone. Might as well bite the bullet and make your own
