SDA 1-C's: twin blade or pin/blade cable ?
mhw58
Do the SDA 1-C's use the blade/blade interconnect
cable of the pin/blade one?
THanks, Mike
THanks, Mike
Fronts: SDA1C's
Rears: SDA2's
Center:CS400i
Sub: PSW505
Rears: SDA2's
Center:CS400i
Sub: PSW505
Only the pin/blade....Oh, the bottle has been to me, my closes friend, my worse enemy!
Nascarman,
Are these pin/blade cables available anywhere? Polk
still makes the twin blade but no the pin/blade.
MikeFronts: SDA1C's
Rears: SDA2's
Center:CS400i
Sub: PSW505 -
Polk won't make them, you can make one, search the forum somebody had a diagram and posted it, it was easy take speaker wire RCA plug striped to just the pin and a spade terminal.Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
Ok, here we go again...
A recap of 'HOW TO' make your own Interconnect Cable 'Pin and Blade Connection' for SDA type speakers. Since then my SDA's
still perfectly sounding awesome...
http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=2872
Enjoy reading...my diagram of HOW TO.
Har -
On the 1-C the cable is pin/spade, I need to make a cable, does it run pin to pin or pin to spade ?
FYI they made 1c's with pin/blade and blade/blade. I have a set of each if you're looking.
Its been 6 years and just noticed your reply, can still use as cable
It's a safe bet it's Long gone. Might as well bite the bullet and make your own
