BluRay Hook-up to Polk Audio Surround Bar 360
jothom122
jothom122 Posts: 3
I recently purchased ( I am awaiting delivery) of a Polk Audio Surround Bar 360. It comes with a DVD player but I already have BluRay player that I want to hook up to the unit when it comes. Does anyone have an idea how I would do this?
Thanks,
John
Post edited by jothom122 on
  • packetjones
    packetjones Posts: 1,059
    edited July 2010
    It looks like there are optical inputs on the back of the unit. I would connect the BDP to the TV and run the sound to one of the optical inputs. You would either run the optical from the TV to the unit or form the BDP to the unit.
    Hope this helps.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • jothom122
    jothom122 Posts: 3
    edited July 2010
    Thanks for the info. I don't want to seem too dense, but, what is the BDP and, when I do get the unit, what do the optical inputs looke like?
    Sorry for being so naive about this.
  • kawizx9r
    kawizx9r Posts: 5,150
    edited July 2010
    jothom122 wrote: »
    BDP meaning your bluray disc player.
    Does your TV have hdmi inputs and optical outputs?
    Best way I'd run it is, hook up your bluray player to your tv via hdmi (that way you have both video+audio sent to your tv).
    Run the optical from either your tv (if it has one) or the optical/analog from your bluray player to your surround bar.
    Whenever you want to use the surround bar, just put the tv's volume down to 0. Hooking it up this way allows you to watch/hear movies through your tv in case you don't want to use your surround bar and not have to connect/disconnect anything else.
    Btw, welcome to CP!
    -Freddy
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • jothom122
    jothom122 Posts: 3
    edited July 2010
    Freddy,
    Thanks for the help, appreciate it.
    John
