Loose banana plugs
sonvolt
Is there a way to make a banana plug fit more snugly in the terminal post socket? My ATI 2505 amp seems to have loose sockets compared to the Carver AV-505 I have.
HT Set up: Samsung 58" plasma, Outlaw 950 pre/pro, ATI 2505, Monitor Audio Silver series (fronts and center), AR 12" sub, Velodyne VX-10 sub, Boston Acoustic rear surrounds.
Post edited by sonvolt on
I had that problem before, so I switched to locking banana plugs and it worked out fine!
Btw, welcome to CP!
-FreddyTruck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
What brand of banana plug?
You can most likely pry out the bowed pieces, if yours has the bowed type head.Political Correctness'.........defined
President of Club Polk -
I got them at monoprice. I will try prying one out and see what happens.HT Set up: Samsung 58" plasma, Outlaw 950 pre/pro, ATI 2505, Monitor Audio Silver series (fronts and center), AR 12" sub, Velodyne VX-10 sub, Boston Acoustic rear surrounds.
some of the cheaper nanners' fins tend to flatten out over time. It happened on mine GLS nanners. I replaced mine with Audioquest's bayonet and it solves the problem.I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
some of the cheaper (Monoprice $2.28 each) nanners' fins tend to flatten out over time.
What he said.Political Correctness'.........defined
Mine, on my MIT wires seem to be holding up just fine even though I crank my system up a lot.HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
Buy some quality nanners.SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
Take a pen, or something with a tapered point and push it in the middle of the connector where the sides have collapsed in on themselves. As you push in, the sides will expand outwards. Works like a charm.Living Room: Receiver: Pioneer Elite SC-25 | Turntable: Technics SL-B200 | CD Player: Rotel RCD-955AX | Fronts: Polk RTiA3 | Center: Polk CSi A4 | Rears: Polk FXi3 | Sub: Velodyne DPS-10 | Cables: AudioQuest Type4 & TypeA
Office: Carver HR-742 | Speakers: RTi6 | Turntable: Numark 1600 -
i did this to my AQ cables. great fix -
Yeah, my AQ Type 4s had the same issue, but that little fix makes them just as tight as the day they were bought.
