Loose banana plugs
sonvolt
sonvolt Posts: 8
edited July 2010 in Troubleshooting
Is there a way to make a banana plug fit more snugly in the terminal post socket? My ATI 2505 amp seems to have loose sockets compared to the Carver AV-505 I have.
HT Set up: Samsung 58" plasma, Outlaw 950 pre/pro, ATI 2505, Monitor Audio Silver series (fronts and center), AR 12" sub, Velodyne VX-10 sub, Boston Acoustic rear surrounds.
Post edited by sonvolt on
  • kawizx9r
    kawizx9r Posts: 5,150
    edited July 2010
    I had that problem before, so I switched to locking banana plugs and it worked out fine!
    Btw, welcome to CP!
    -Freddy
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
    F1nut Posts: 51,778
    edited July 2010
    What brand of banana plug?
    You can most likely pry out the bowed pieces, if yours has the bowed type head.
  • sonvolt
    sonvolt Posts: 8
    edited July 2010
    I got them at monoprice. I will try prying one out and see what happens.
  • polkatese
    polkatese Posts: 6,767
    edited July 2010
    some of the cheaper nanners' fins tend to flatten out over time. It happened on mine GLS nanners. I replaced mine with Audioquest's bayonet and it solves the problem.
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
    F1nut Posts: 51,778
    edited July 2010
    some of the cheaper (Monoprice $2.28 each) nanners' fins tend to flatten out over time.
    What he said.
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited July 2010
    Mine, on my MIT wires seem to be holding up just fine even though I crank my system up a lot.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • fbm211
    fbm211 Posts: 1,488
    edited July 2010
    Buy some quality nanners.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • hagmanm2
    hagmanm2 Posts: 205
    edited July 2010
    Take a pen, or something with a tapered point and push it in the middle of the connector where the sides have collapsed in on themselves. As you push in, the sides will expand outwards. Works like a charm.
    Living Room: Receiver: Pioneer Elite SC-25 | Turntable: Technics SL-B200 | CD Player: Rotel RCD-955AX | Fronts: Polk RTiA3 | Center: Polk CSi A4 | Rears: Polk FXi3 | Sub: Velodyne DPS-10 | Cables: AudioQuest Type4 & TypeA
    Office: Carver HR-742 | Speakers: RTi6 | Turntable: Numark 1600
  • acmf74
    acmf74 Posts: 937
    edited July 2010
    hagmanm2 wrote: »
    i did this to my AQ cables. great fix
  • hagmanm2
    hagmanm2 Posts: 205
    edited July 2010
    Yeah, my AQ Type 4s had the same issue, but that little fix makes them just as tight as the day they were bought. ;)
