What is the different of the two speakers
Phil_12345
Hi,
Futureshop has a sale of PSW111 - one is for $129 and one is for $249.
Why is the different in price of the same model #
http://www.futureshop.ca/en-CA/product/polk-audio-polk-audio-8-subwoofer-psw111-psw111/10130311.aspx?path=2d89a1f5ae5562ff8eaf5870feb581e6en02
and
http://www.futureshop.ca/en-CA/product/polk-audio-8-powered-subwoofer-psw111/10086832.aspx?path=7858dea8d69cbdf56fed5888605a8b84en02
and
Post edited by Phil_12345 on
There is no difference, except that the cheaper one is sold out. I suspect only FutureShop would be able to answer *why* they have two different prices for the same speaker.Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH -
The only thing I saw was that the model # on one of them was PSW111 and the other was PSW111WP - No idea if that makes a difference or not, however if you look at the comparison view, the more expensive WP model indicates that it has a crossover where the other does not--Of course I never fully rely on those comparison specs as I've always foudn them to be less than accurate.____________________
Pool: Atrium 60's/45's -
Futureshop is also NOT an authorized Polk distributor so if you purchase from them, kiss the warranty goodbye.
Below, you will find a list of Authorized Online Polk Distributors...
http://www.polkaudio.com/dealerlocator/online.php~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
The search for Polk dealers in Canada shows that Future Shop is a valid CANADIAN distributor.polkaudio Monitor 5 Series II
polkaudio SDA-1 (with the SL1000)
TEAC AG-H300 MK III stereo receiver
beyerdynamic DT-880 Premium (600 Ω) headphones
SENNHEISER HD-555 headphones
Little Dot MK IV tube headphone amp
Little Dot DAC_I balanced D/A converter -
I went into FS this evening and had this checked out.. I have searched high and low and have come up empty regarding any validity regarding a special FS only model.
They certainly wouldn't price match the one I bought last month and there aren't any in stock across the province. -
Hi,
I don't know if this is a 'bail and switch' tactic of Futureshop. The cheaper price one out of stock province wide instantly when the sale is started.
I questioned the sale rep and he said the cheaper one is "promotion" model from Polk Audio - again, more confusion !!!
BTW, what happend to: "if the sale item is out of stock, the shop MUST either give you a rain-check and/or sale you a similar model at the sale price" . In this case, FS must sell the other PSW111 at $129 -
If you read the description right under 'Features & Specs' then it is also indicated that the one on sale is also PSW111WP.
The Polk Audio PSW111WP subwoofer picks up the slack where other woofers fall flat. It features an 8" Dynamic Balance Kippel Optimized woofer and a 300W power amplifier with a down-firing port for enhanced bass performance in a very compact design.
Either way, I don't trust their comparison spec either. -
Ah, thank you for clarifying. I did not know this.The search for Polk dealers in Canada shows that Future Shop is a valid CANADIAN distributor.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
I went in to FS again and they told me that the cheaper one was a FS only special made just for them by polk and that they were clearing out all the old stock.
I was told "different squeue, different product". A friend of mine in Dartmouth looked at both side by side and saw no feature difference. Go figure. -
Phil_12345 wrote: »Hi,
No movement from FS on this. I bought one from FS less than 30 days ago with the same model No. on the receipt. won't do a price match as they keep telling me that they are two completely different models. My friend tells me that they made two models from with slightly configuration. Most notably, a three prong power cord vs a two prong cord and the LFE is combined with the left RCA input. -
Futureshop is a major chain store in Canada.
They were there before Best Buy.
It is impossible that they would not be an authorized dealer since they carry Polk Audio.
Futureshop was purchased by Best Buy in 2001 I believe, so it makes sense that if Best Buy is an authorized dealer, the same would be true for Futureshop. -
Future Shop, Costco, BB, etc. are all known for this shady practice - they get "shop exclusive" models, which are no different from the "normal" models (TVs, receivers, speakers, etc). This way you cannot price match one store to another when the item is on sale at one store. Especially valid for FS/BB, since they are under the same ownership.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
Both has the same regular price of $384.99 without the discount. Therefore, they are both pretty identical to me. FS must doing something pretty shady about this ??? -
I don't know about the rest of you, but for me, when I see this kind of cr@p going on, from that day forward that firm has lost my business. Boycott a business that is shady! If everyone did this, maybe these shady deals would cease! There is no reason to put up with this kind of business. There are other businesses which actually try to be honest and up front with customers.Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com
