wanted to get some input on my setup.
If I dind't say it yet or even repeating my self, "Welcome to CP"
Didn"t I tell you not to let some of these folks to not spend your money before you earned it
505 is too expensive, been at 249$ for a long time, even lower than that lately... you have to keep in mind this is an obsolete Polk product, part of their vintage product.
THANKS! Yes you did........... $$$$$
how about the microPRO then? just found a Refurb one for $285 shipped from Polk Direct
i like the MFW-15 Subwoofer that bsoko2 has FS. but not the $443 pricemole' -
Mole' are you made out of money? What an aggressive buying streak... I like it... haha
grimmace19 wrote: »Mole' are you made out of money? What an aggressive buying streak... I like it... haha
i may soon have a set of SDAs too.
heHeHe
new to the site, so i have to catch up with you guys...........mole' -
Well, it shouldn't be long before the 70s and cs2 show up for you. I did put signature on them for you so hopefully that doesn't set you back a day like it always does for me.
grimmace19 wrote: »Well, it shouldn't be long before the 70s and cs2 show up for you. I did put signature on them for you so hopefully that doesn't set you back a day like it always does for me.
ya, cant wait to hear them 70s. i found a place for the CS2. above my TV.
BTW, how did you ship it? and DONT FORGET my feedback ratingmole' -
hooked up the Monitors 70 for my Fronts, put the 50s for the rears and the 40s for the SS. the CS2 sounds way better than the lil RM7cc i had. i need a bigger Sub or maybe get another one for a matching set of PSWi225smole'
The microPRO subs are better for your HT requirements. Polk eBay is the place for good deals and refurb or use is always a good idea (maximize every of your $$$ spent).THANKS! Yes you did........... $$$$$
i like the MFW-15 Subwoofer that bsoko2 has FS. but not the $443 priceDARE TO SOAR:
only microPRO that the ebay store has is the 2000 8" one. they said 284 shipped. how do you think it would sound with the PSWi225. have both of them hooked up or just sell the PSWi225 and maybe get 2 of the mP 2000 8" ones.
265 a pop if i buy 2 of themmole' -
If you compare specs for both of the subs you'll notice that the PSWi225 goes down to 36 hz while going down to 27 hz. I feel just that alone may affect the overall performance of using those 2 subs together. However, since you already own the 225, may I simply suggest you order only 1 2000 first and do some audition to see how the both blends and how you like it? The positive of the 225 is that you can easily move it around without cable pain since it is wireless (the 225 would be perfect if located far away from the receiver)DARE TO SOAR:
put the mP 2000 in the front of the room and the PSWi225 in the rear.
i would like to have a bigger sub, like a 12" or 15" but have not found anything near that price range.
Thxmole' -
bigger size doesn't necessarily mean better. Go with a brand that is known for making good subs.....like SVS.
If you're going to drop coin on SDA's, make sure you have a listening wall with adequate placement options. Otherwise, you won't get the full SDA effect and your money might be better spent on other equipment.
If you want to use the Adcom power amp, you'll have to end up selling off the Denon and getting a Pre that has pre-outs.____________________________________________________________
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, McIntosh C2300, Marantz AV7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Sim Audio Moon 380D DAC, EPSON Pro Cinema 6050 -
i put off them SDAs i was looking at.
looking at a better AVR now. 3311ci has my eye for now.mole' -
B&K Ref 10 showed up yesterday. idk if i even need it now.
my setup has changed now
AVR Pioneer Elite SC-07
AMP Adcom GFA-545 MKII
AMP Acurus 250x3
MIT Speakers cables
AQ ICs
speakers
M70, M50, M40, PSWi225 for now
RTi12 and a better Sub or LSi 25 soon to comemole' -
so since joining this site, my system has done a 360* turn for the better
SC-07 AVR
BDP-23fd
Acurus 250x3
APC s10
SDA SRS 2.3TL's
CSi5
Epik Castle 15" sub
MIT AVt-3
MIT EXp-1
AQ King Cobras
AQ CV-8
have the SDA SRS 2.3TL's for my mains, CSi5 for center, Monitor 40 for my rears, gonna hook up the OWM3 as read sides, and the Epik. just got done watching the Avatar and im loving this setup so far. i know the speakers dont really match, but its gonna have to do for now.
Monitor 70s are (RIP) gone(UPS)
Pioneer Elete VSX 84TXS, Adcom 545 MKII (unless it sells), Monitor 50, CS2, OWM3 (second set), set of Sony 125watt bookselfs and PSWi225 will be pulling the bedroom/bathroom duty now. have my second PS3 60gig and a Monster power center HTS1600 to go with it. i have extra AQ cables and monoprice speaker wires. bedroom is 18x14x10 and bathroom is 18x10x10. i have a 40" vizio as the main TV and then i have a 32" vizio right about the spa tub for the wifey. gonna put the OWM3s in the bathroom for theSS for the TV. i just have to figure out how to run 2 HDMI outs. was looking at using one of these. http://www.monoprice.com/products/product.asp?c_id=101&cp_id=10113&cs_id=1011301&p_id=5418&seq=1&format=1#largeimage with this
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10240&cs_id=1024006&p_id=2803&seq=1&format=1#largeimage
*NOTE: Direct TV users, HDMI cables at this length may not be compatible with your devicemole' -
pics of the setup plsHT and Music Rig
Receiver- NAD T765 HD
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Surrounds side- Polk Audio Monitor 60
Sub- Polk Audio PSW505
Windows 7 Media Center
T.V.- 40" Sony Bravia LCD 1080P
Blu-Ray- 80 GB PS3 -
http://www.polkaudio.com/forums/showthread.php?t=105756
i have added since a pair of Monitor 10smole' -
looking to upgrade my rear SS speakers in my bedroom. mains/fronts are RTi10s, center is CS2 (looking for a CSi5/CSi6) OWM5, PSW1225, Pioneer Elite VSX-84TXSi, XPA-3, Vizio 42" plasma, Direct TV HD box, PS3 60gig. MIT EXp-1 speaker wires, monoprice speakers wires/HDMIs/ICs
i was thinking a set of RTi4 or RTi6 would be better for the rears.
any ideas?mole' -
Damn bro, how bigs your bedroom :eek: lolTruck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
LOL!!!
30x28
its bigger than my front room
still thinking about putting the 2.3TLs in my bedroom. im liking the sound from the RTi10s more now.mole' -
LOL!!!
30x28
Ahhh blasphemy!
2.3TL's continue to be my FAVORITE of all Polk speakers (that I've heard), I need to swing on by your place and check your setup out and maybe move a few things around while you're taking a look at my car
Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
Ahhh blasphemy!
sounds good!
so any inputs on the rears? RTi4 or RTi6 or some FXi speakers?mole' -
sounds good!
Any of the F/X dipole/bipole speakers have great diffusion, I'd probably pick those over conventional book shelf speakers.Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
so i found a good deal on a set of FXi3's and a CSi3
both in black. these will work til i can find a set of FXi5's and a CSi6.mole' -
so i hooked up my Adcom GFA-5802 Amp that i got from Larry. its hooked up to my SDAs. i took the Acurus out and hooked up the EMO XPA-3 to power my CSia6 and FXi4s. i think the EMO amp woke up the CSia6 for sure. FXi4s sound about the same.
SDAs sound louder at the same volume than before. gonna have to watch Avatar and WOTW to see how it all sounds now.
the acurus is going in the bedroom now to power the RTi10s and CSia5
BTW i unhooked the SDA cable because im not sure if its OK to run them without the ground wire Larry was talking about. did not wanna mess up my SDAsmole' -
Added the Adcom and EMO amps. this tower is getting HARD to move now
what looks better on the EMO. black or silver trim?
mole' -
Black!"They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
messiah, November 23rd, 2010 -
Black!
+1
In your setup, I'd go with the black trim.
Btw, how much weight does your rack support?! :eek: (Lol think that line set me up for something
) Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
i would move the AVR to a lower shelf or get something that can support more weight. you don't want to come home to a dead rack.
+1
OH MAN!
your lucky im being nice todaymole'
