MIT Selectable Impedance IC settings
inspiredsports
inspiredsports Posts: 5,502
Does anyone know which impedance setting I should us on MIT Shotgun IC's between a Conrad Johnson PV-5 pre and a VTL ST-50 amp?
Setting choices in K ohms are 5-50m 40-100 and 90 and higher. I think the CJ is at the higher end and am using the 90 and over, but I don't have a manual for either component so I don't know for sure.
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels
Post edited by inspiredsports on
  • kawizx9r
    kawizx9r Posts: 5,150
    edited July 2010
    This was covered elsewhere, I'll look for it. Personally though I go with what sounds best...let me check my manual and see what it says specifically.
    -Freddy
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • kawizx9r
    edited July 2010
    Ok it says in my manual for best results each interface (cable) must be matched to the input impedance of the component receiving the signal, or the destination component.
    Edit: Here's the thread - http://www.polkaudio.com/forums/showthread.php?t=103278&highlight=impedance
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • Ricardo
    Ricardo Posts: 10,634
    edited July 2010
    Needs to be set based on the receiving piece's input impedance, so in your case the VTL amp. I would go with the 40-100 until you can find the specs. Or as Freddy says, see what sounds best. You won't break anything.
    SOPA
    F1nut Posts: 51,919
    edited July 2010
    You should be able to get the input impedance info from the respective companies.
  • george daniel
    george daniel Posts: 12,096
    edited July 2010
    If it helps--my VTL mono's have an input impedence of 137 K ohms
  • inspiredsports
    edited July 2010
    Thanks all, I do have them set on the 90 and higher setting as that's where it sounds best to me, but it is so early in getting to know the amp that I want to find out for sure. I wrote to VTL earlier today and haven't heard back yet.
    Greg
    NAD SS rigs w/mods
    GIK panels
    F1nut Posts: 51,919
    edited July 2010
    Greg, I'd suggest you call them, talk to Bea.
  • BlueFox
    BlueFox Posts: 15,250
    edited July 2010
    My MIT S1.3 XLR ICs have an overlap range between each setting. Currently I have mine on the low setting, but tomorrow night will switch to the medium setting. I am pretty comfortable with how they sound now so any difference should be apparent.
  • inspiredsports
    edited July 2010
    That's a name I picked up in another newsgroup where a strange character from the Atlanta area named "Dangerbird" found her :). I will give her a call tomorrow.
    NAD SS rigs w/mods
    GIK panels
  • george daniel
    edited July 2010
    That would be me,, check your pm
  • inspiredsports
    edited July 2010
    I knew that. That's why I chided with ". . . a strange character from . . . " :D
    I researched the heck out of this amp after sending the funds to find out about setup and what kind of tubes I might want to roll. I'm just warming her up to listen again this morning as I work.
    I love it when you listen to familiar music and hear things you never knew were in the mix before, and this amp definitely allows for that! Knopfler's Philadelphia is cued up on the turntable.
    How long did you normally allow for warm up? 10-15 min?
    NAD SS rigs w/mods
    GIK panels
  • george daniel
    edited July 2010
    I usually let it warm up for 15 minutes,, 20-30 if I'm gonna check bias,, and what I found was ,, after about 45-60 minutes she really starts to sound sweet.Don't be like me and check the bias every day,(my early tube days ;)), set it and just enjoy,I think that you are finding out that this little amp will surprise you.Enjoy it. :)
  • BlueFox
    edited July 2010
    BlueFox wrote: »
    I left my settings on low. The MIT range's are 0 - 50K (low), 40k to 100K (mid), and something else for high. Anyway, the balanced input impedance for the Cambridge-Audio 840W is 38K. I was thinking it was 48K. So much for memory. :rolleyes:
  • hearingimpared
    hearingimpared Posts: 21,136
    edited July 2010
    kawizx9r wrote: »
    -Freddy
    No truer statement has been uttered.;)
  • inspiredsports
    edited July 2010
    kawizx9r wrote:
    . . . personally though I go with what sounds best...let me check my manual and see what it says specifically. -Freddy
    No truer statement has been uttered. ;)
    Yes, but you know me; by the book with i's dotted and t's crossed, and THEN I start experimenting. :D
    NAD SS rigs w/mods
    GIK panels
  • hearingimpared
    edited July 2010
    My tube pre input impedance is very high. I wonder it this is the norm for all tube gear?
