Need Suggestions on Setup Please
cliffli
Thanks in advance. Moving into a new home and my new rec room is 28x13.
I have the following but don't know which is the best setup. The left over I will use in a different room.
Onkyo TX-SR 707
M70s
M60s
M50s
M40s
M30s
DSW PRO 600
BIC F-12
Or do I need to get some more powerful than a 707?
Really dont know which way to go here.
Onkyo TX-SR 707
M70s
M60s
M50s
M40s
M30s
DSW PRO 600
BIC F-12
Post edited by cliffli on
Forgot to add:
CS2 Center -
Welcome to club polk. If I were you I would definitely go with 70s up front, 60s in rear and the 50s as your surrounds assuming you are going for 7.1, if you are probably the dsw...but why not go all out and use both subs especially in a room that size:p:D Will definitely help fill the room with those lows helping to fill any nulls and voids that you might experience using only one sub.I love animals, they're delicious!
The 707 should be fine for moderate listening levels in that size room. However, you might consider external amplification to really get the most out of your speakers. I would recommend snagging a 3-channel amp for the front soundstage, then letting the 707 handle the power for the surrounds.
I would also highly recommend looking into a more capable subwoofer since your room is so large.Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
Thank you very much...I will try the 7.2 setup. can the 707 drive all of these or should I definitely get an external amp? So would the external drive the fronts and center only? Any suggestion on an amp and a sub if these two are not sufficient? Thank to both of you..
i suggest use m40 as rear, m30 as surround, mounted 2 ft above listening level..dolby sound track are designed that way
use m70 as front and throw m50/60 somewhere else..
707 should be fine.Front: Martinlogan ESL
Center: Martinlogan Stage
Rear: Martinlogan Motion 4
Sub: Martinlogan Grotto-I
Receiver: Pioneer Elite SC 1523K
PC 2 Channel: Polk LSI7
Headset: Grado RS2 + Grado RA1 amp
Mic: Neumann KMS605
Car Audio
2002 MB C240 Sedan
MM6501 components
MM840 sub
MB Quart Onyx 4.60 (1/2 to components, 3/4 bridged to sub)
Pioneer 8200BT HU -
my M70s should be here anyday now.
im planning on M70s for the fronts, M50 for the rears, M40s for the SS and a CS2 for the CC. i have a pswi225 for my sub, but plan on upgraded here soon.
your setup will be close to mine minus you have more boom!mole' -
appreciate all the suggstions. I see that I will hae to experiment until I get it just right.
mole...looking forward to hearing what you think when your m70s arrive.
thanks all -
