In-Wall equipment rack
Lowell_M
Hey all, I haven't been around for a while... having a baby will do that to you I guess.
Anyway... I built my gear into a wall in my current HT with shelves made out of MDF. It turned out ok, I guess but I'm not completely happy with the fit and finish.
Do any of you have any recommendation of how to build a rack into the wall? (So the front of the gear would be flush with the wall and the gear goes back into the wall.)
HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Post edited by Lowell_M on
It will hopefully be in a new place, but here is a link to a thread where you can see my current rack...
http://www.polkaudio.com/forums/showthread.php?t=95036&highlight=lowell_m
We decorate clean and contemporary. No need for any doors to cover it up and connections will be made in a fake closet in the next room.HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Ultra Bi-Wire Speaker Cables -
I'm curious. Can you access the rear of your equipment via a panel in the other room?Sounds good to me...
As simple as this sounds, put some trim around it. It will make it look much better.
Example:
If you put a door on the rack.... what do you do for IR signals from remotes? I door might be nice. Any recommendations for the pro-looking racking?
I've thought about trim. Might at least go that route.HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
You buy the IR repeater and install it.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
Well... when you put it that way... it seems like a really stupid question.
HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
you could put a tinted glass door on it and the remotes should work
I'm doing mine with a Middle Atlantic rack, then usig custom face plates for the equipment to give it a clean flush look. Of course I haven't started this yet so I don't ahev any pics, but I'll try to find some of the threads from the guy I bought the rack from.
Of course since you already have your nook in place, maybe you could just add some threaded rails to support the custom faceplates without having to actually use a whole rack. ???
Otherwise, adding trim, as Zeroes suggested, would make a big difference.____________________
Pool: Atrium 60's/45's -
Here we go, this post shows a pic before a rack with shelves like yours:
http://www.polkaudio.com/forums/showpost.php?p=755043&postcount=9
And this post shows after with the rack and faceplates.
http://www.polkaudio.com/forums/showpost.php?p=959971&postcount=4____________________
Trimmings definitely adds som style and class :cool:As simple as this sounds, put some trim around it. It will make it look much better.
Example:
Exactly and would also look spiffy, not counting that you will keep dust away from the gear (I hate dusty gearmewisemagic wrote: »you could put a tinted glass door on it and the remotes should work
mmadden28 links leads us to great idea also :cool:DARE TO SOAR:
