PSW505 too much for small room?
JCA
Hi,
I am new here, and I would appreciate any comments or advice about how to upgrade my HT set up.
I have a small room about 15 x 15 feet, I already have setellite speakers (Boston Acoustics, FR:35 -20K Hz) and two 8 inch subs: one BA (35-200 Hz) and one Polk PSW111(32-250Hz/150 watts). The bass output is tight and musical, but I would like to get to lower frequencies, below 30, and to get more powerful sound for movie watching, which I can not get right now.
I was planning to replace the old BA sub, by a ten incher, but the models I have checked so far don´t have the frequency response I am looking for. I was planing to settle for a Def Tech Prosub800 (20Hz) or a Prosub1000(18Hz), when I read reviews of the PSW505, that I can get in the internet for a fairly discounted price.
My question is; If I replace the two small subs with the PSW505, would it be too much bass for a room this small, would it overkill the sound of the satellite speakers.
Any recommendations? (Please bear on mind that I am a casual user).
Post edited by JCA on
WELCOME TO CLUB POLK!
The simple answer is "NO" your room is not too small for a PSW505. It will work fine in that sized room. You just have to tweak it a bit but that's easy enough! It's also a very nice HT sub for those very effects you are looking for. Hits louder and lower than anything else you have.
Good Luck.
Welcome to CP!
I had that Polk sub and it was great for HT. The walls will rattle a little so if you have neighbors in a apartment or condo that might be more of a consideration. But my no means is it too big for your room....enjoy!:pHT System
Parasound Halo A51 Amp, Marantz AV 8003 Pre, Arcam FMJ CD36 cd player, Marantz 7007 BD/SACD player,Acoustic Zen Matrix IC's, Analysis Plus Crystal Copper Oval IC's, Acoustic Zen Satori speaker cables, B&W 703's Fronts, Center Martin Logan Motif hybrid, Surrounds DefTech BPX, 2 X DefTech Supercube Reference Subs, DSpeaker Antimode 8033 EQ. -
Hi JCA,
I own the Polk PSW 505 and am really enjoying it. It has its own volume control, so experiment with the tweaking (volume, placement in the room, etc ...) that cnh recommended, and have fun with it!
Best Wishes,
Pappy
AVR - Pioneer VSX 9040TXH
TV - Samsung HL-T6756W DLP
BD - Panasonic DMP-BD605
Cable - CableOne HD DVR
Fronts - Polk Audio Monitor 70s
Center - Polk Audio CS2
Rears - Polk Audio Monitor 60s
Subwoofer - Polk Audio PSW 505
Some Monoprice 12 AWG wires (and others)
2 Channel (in Progress)
Sansui S-X1100 receiver (from somewhere between 1985-1988, inclusive)
Bose (I know) 501s (purchased Fall 1978)
Technics SL 1700 Turntable (purchased Fall 1978)
(Sold my 1976 Pioneer SX838 receiver – big mistake) -
Welcome to CP. I also have the 505 .my room is 15x20 and it works fine. Just play around with the volume till it sounds good for you.Marantz SR 7007
polkaudio RTi10
polkaudio CSi A6
polkaudio RTiA3
B&K ST.3140 Power Amplifier
HSU Research VTF2 MK3
Vizio P65-C1
Panasonic 605 blu ray
Onkyo DS-A4 i-pod Dock
Universal Remote
BDI Icon 9429 TV Stand -
I agree with everyone's feedback, I have the 505 and it's a great sub for HT. Just tweek it to fit your taste and enjoy! It well worth the price you can get it at now! Welcome to CP!Main Rig:
Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
Second Rig:
Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded) -
I agree too that it is not too big. I am in a 15X20 room, maybe a little bigger. On days I am not into all the bass I use the volume control on the back.
By the way I am new too!System:
Samsung LN46C630
Receiver: Yamaha RX-V1
DVD/Blu: Denon 2910/Playstation 3
Front mains: RT16
Front presence: F/X 500i
Center: CS400
Rear surrounds: RT1000p
Rear center: RT7
Subwoofer: PSW505 X 2
Marantz 2252B
Technics SL-Q2 turntable
Kef Q50 -
polks older subs make alot of port noise on HT stuff due to the ports not being big enough to accommodate the air turbulence of loud sounds below 30hz sounds, getting a psw505 would not be overkill at all. the lower you can go the less port noise with the older polk subs, i have a psw10 and anything below 30hz causes port noise. also there is no such thing as overkill on a sub, the less the sub has to exert itself the lower distortion and port noise you will have.
Thanks a lot everyone for your comments, I appreciate it, now I feel confident that the PWS505 will be fine for my HT.
While I did my resarch about what sub would work for me, I also came across some models from Mirage (PrestigeS10), HSU (STF-2), Velodyne (Impact-12) and Klipsch (Synergy Sub-12). All had good specs, but were out of my budget. I singled out the 505 as a good value, considering cost and features.
Thanks again for the help!
JC -
Hi JCA,
I also liked the subs that you just mentioned, but like you, they were out of my price range. I have no regrets with the PSW 505 (that doesn't mean that I wouldn't consider upgrading some day). Let us know what you think of it when you get it.
Best Wishes,
Pappy,
Home theater
Toshiba DVD player (to play CDs - uh oh!)
