Onkyo 706 into Standby with external amp
grimmace19
grimmace19 Posts: 1,429
edited August 2010 in Troubleshooting
So here's the deal, I just got the lsi's setup and running through my Adcom GFA-7500 with my onkyo 706 running pre duties. After listening all morning at moderate levels at best I re-calibrated the receiver for crossover duties to 80hz as a starting point. Then after turning things back on and watching a zeppelin blu-ray the receiver went into standby mode at around -20db I guess I don't understand why this would be the case when I'm not powering any speakers off of the receiver but only the amp.
Any insight?
Post edited by grimmace19 on
    Toolfan66 Posts: 17,998
    edited July 2010
    Double check all you hookups first "all of them", Then recalibrate.
  • jrgoswick
    jrgoswick Posts: 159
    edited July 2010
    When I was using my 705 as a pre it got hot a lot. Make sure you have plenty of ventilation room because it will STILL GENERATE HEAT from the amps inside, just not as much. Gave mine room to breath and it cured the problem. Also do as TFL suggested.
    Onkyo TX-SR705 AVR
    Onkyo M-501-Given to my father.
    Onkyo DX-C730 CD Changer
    Onkyo DV-BD507 Blu Ray player
    Onkyo CP-1036A turntable with Grado, Audio Technique, and Azden cartridges(GOT CARTRIDGE??)
    Polk Monitor 12's with RDO's and XO's
    Polk CS300 Center
    Polk Monitor Series 4 rears
    EBAY is like cocaine. At first you only look, next thing you know, your house is full of crap you have no idea why you own.:eek:
  • devani
    devani Posts: 1,497
    edited July 2010
    disconnect all wires and turn on...see if it happens again
    Video: LG 55LN5100/Samsung LNT4065F
    Receiver: HK AVR445
    Source: OPPO BDP-93
    HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
    2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83
  • grimmace19
    edited July 2010
    Well, it's been running all day at low volumes and hasn't done it again. I think things are all ok and should be fine once the new interconnects show up.
  • grimmace19
    edited July 2010
    Alright, interconnects are here. They certainly improved the volume but didn't truly fix the issue. Got the sound to around -15db on the receiver and it went into protect mode again. Any other thoughts or solutions before sending this damn thing back? I did a factory reset once and got the same results.
  • geebolt
    geebolt Posts: 215
    edited July 2010
    Did you ever find the problem? I have an Onk 807 driving an Emotiva XPA-5 and it (the Onkyo) went into standby mode one time on me out of approximately 25 hours listening. It was at fairly high volume but but just went into standby for no reason. No one was even close to the remote. Turned it back on and its been fine since but can't help but wonder after reading your post...
    Fronts: Polk RTi A7's
    Center: Polk CSi A6
    Surrounds: Polk TSi500's
    Subwoofer:Polk DSW Pro 500, Emotiva Ultra 12
    Amplifier: Emotiva XPA-5
    Processor/AVR: Emotiva UMC-1
    DAC: Emotiva XDA-1
    CD player:Emotiva ERC-1
    Blu-Ray: Oppo BDP-93
    Turntable: Kenwood KD-500
    Tonearm: Polk-Mayware Formula 4
    Cartridge: Shure M97-XE
    Television: Sony KDL-55EX500
  • grimmace19
    edited July 2010
    Never found the solution. This thing was shutting off at -25db after 2 minutes so it was messed up pretty bad. I just got issued a full refund from the ebay seller this morning for it.
  • mole'
    mole' Posts: 3,160
    edited July 2010
    grimmace19 wrote: »
    that sucks it was messed up.
    what are you gonna get now for an AVR?
    mole'
  • grimmace19
    edited July 2010
    I have a Marantz 7002 on the way from amazon... its new in box but the product is about 2 years old i believe. 1400 retail and only paid 600 :)
  • mole'
    mole' Posts: 3,160
    edited July 2010
    grimmace19 wrote: »
    oh ya, forgot about that. you will have your tunes up in running in no time.
    mole'
  • grimmace19
    edited August 2010
    Well, after all the turmoil the Marantz SR7002 arrived today and I got it from the office after work. After the quick hookup since everything was still back there from the Onkyo I am loving every minute of the new setup. After what has turned out to be just under a month from picking up the LSI's I feel that everything is finally operating as it should and it sure sounds nice. A fantastic upgrade from the Monitor 70s (though good starter speakers) I am finally confident I have a system to build upon rather than overhaul. Once some more wedding gifts start rolling in it will certainly be time to add some 7s or 9s for surround duty!
    Thanks again to everyone that helped along all the issues but to sum a few other things up. The circuit breaker no longer pops, the receiver doesn't go into protect mode, the speaker volume is great, and overall just sounds amazing. I believe whole heartedly now that the Onkyo must have had some major electrical issues if the protect mode and circuit breaker issues were solved immediately after unboxing the marantz.
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited August 2010
    Awesome news Grim, glad to hear you are back up and running. That Onk must have had issues, because it shouldn't have acted that way. I just put 806 into protect mode a few weeks ago and it is in the shop now for repairs. Haven't seen you on COD much, you still play?
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • grimmace19
    edited August 2010
    ^ Welcome back Jeff! Haven't been playing at all lately... finally got tired of the game.
  • wutadumsn23
    edited August 2010
    Good to be back man, yeah I hear ya, I am on my last kick myself with that game. Play every once in awhile, after I paid all that money for those crapy new maps I felt I needed to get my moneys worth, lol. FFA is a waste of time nowadays because of the boosters, and we all know how good I am at TDM, lol. Anywhoot, sorry for the derail, carry on.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
    edited August 2010
    Good to hear your Marantz is doing well. Onkyos can be a bit temperamental--do some quirky things occasionally have to be 'reset' or need a firmware upgrade..
    Ask billbillw and Kuntasensei.
    I know I get a glitch here and there every so often. Fingers crossed!
    Jeff, Hope that 806 comes back soon!
    cnh
  • grimmace19
    edited August 2010
    I'm finally confident that everything is acting as it should. Over the past 3 days now having some time off of work and some good movies to watch I have been nothing but pleased with how everything came together. A true upgrade from the monitor 70s (RIP). Everything is so much more clear and quiet when it should be. Everything seems well balanced at this point and even the fiance was surprised by the difference in sound over the past few nights when watching some movies. Now all that needs to happen is to get things resolved with UPS and Mole about those 70s and my audio related stress from the past month should go away.
