FatMat Sound Deadner
zingo
On the tip of some Polkies, I recently picked up 10sq/ft of FatMat XTreme from ebay for $20 including shipping and a roller tool. Having used Dynamat Extreme in the past, I'll be interested to see how this stuff stands up against the more expensive stuff. I've planning on doing the horns and woofer baskets in my Klipschs, as well as the enclosure of my SACDP, and whatever else I can get my hands on.
I'll post SQ and installation results as I apply the mat and play around with it. I just got the box in the mail one week after order, so I'm excited to get my hands dirty.
Nice price. I'm almost out of my roll of Dynamat extreme."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
so you gonna open up your house speakers and line the insides of them with the liner?
how much does/will this help?mole' -
It's applied to the baskets of stamped drivers, not the cabinet itself. I also use it inside gear that has a stamped chassis.so you gonna open up your house speakers and line the insides of them with the liner?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
It's good stuff, excellent bang/buck IMO (did you get the cutting knife too with your order?
) I still have a good-sized piece of it left, looking around for places to use the rest of it.
I also liked this page from their website, might come in handy for people.
http://www.fatmat.com/tek/ohms.htmlSo, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
http://audiomilitia.proboards.com/ -
Is it a bad idea to apply it to the cabinet itself? If so, why?
(I always hated the "Why" question back in school)
StanStan
Main 2ch:
HT:
Other stuff:
Stan
I would second that. I've been unofficially toying with the thought... -
IMHO, since it is quite efficient on the basket I feel it would be wasted on the cabinet it self (not counting that installing to the cabinet wouldn't stop the mechanical metal parts of the basket from vibrating) but let's wait on a more knowledgeable opinion....DARE TO SOAR:
Dynamat or in this case, FatMat is designed to deaden noise issues from vibrations such as sound waves. It is designed to used on metal products. It is not designed to be used as damping material on the inside of a speaker cabinet. There are other products that are designed for that purpose.Political Correctness'.........defined
President of Club Polk -
Just to add the metal backing on the outter part of the product when used on the inside wall of a speaker would cause all kinds of frequencies to go bouncing around the inside of the cabinet.
http://www.polkaudio.com/forums/showthread.php?t=52810&highlight=Dynamat -
hearingimpared wrote: »Just to add the metal backing on the outter part of the product when used on the inside wall of a speaker would cause all kinds of frequencies to go bouncing around the inside of the cabinet.
Good point on the backing.
I'll by applying the FatMat tonight to speakers, so I'll take pictures if I remember.
I'm not trying to argue but to gain understanding, so please humor me. I am trying to understand how the metal backing would cause all kinds of frequencies to bounce around. Isn't the metal backing also damped by the rubberized core material? It certainly will not ring.
Is it because it is smoother than the normally exposed fiber board interior?
I have Dynamat like material covering the interior of my RTA11TL's. It does reduce some of the ringing of the cabinet walls as measured using an RTA FFT waterfall and a calibrated digit (finger) to administer an impulse (tap) the cabinet.
I can't swear that it has made any significant improvement in SQ as I had added Sonic Barrier behind the MW's and sealed the cabinet seams before any listening tests. There were improvements in SQ but it is difficult to determine which brought them.
Obviously, I would like to know if the Dynamat on the cabinet walls is a bad idea so I will know if I should remove it.
StanStan
Main 2ch:
HT:
Other stuff:
How about the car?"The good thing about science is that it's true whether or not you believe in it." Neil deGrasse Tyson. -
It is excellent for applying to the inside of the car door skin and trunk. It also seals the holes that are ofter the the door frame behind where the door panel mounts. Any large body panel that may ring.Stan
Main 2ch:
HT:
Other stuff:
This is for use inside of cabinets:
http://www.parts-express.com/wizards/searchResults.cfm?FTR=sonic+barrier&search_type=main&WebPage_ID=3&searchFilter=sonic+barrier&x=0&y=0
http://soniccraft.com/products/damping/blackhole5.htm
The metal backing of fat mat or dynamat will just add to internal reflections."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I'm still being educated... Will those products effectively increase the acoustic volume of the cabinet?
Part of my goal in using the Dynamat was that it dampens ringing but would not significantly impact the acoustic volume.Stan
Main 2ch:
HT:
Other stuff:
The attached drawing shows where I have the Dynamat, Sonic Barrier and Daycron applied.
StanStan
Main 2ch:
HT:
Other stuff:
The cabinets don't ring, only metal rings.
[QUOTE-Face] The metal backing of fat mat or dynamat will just add to internal reflections. [/QUOTE]
Exactly.Political Correctness'.........defined
Perhaps "ringing" is the wrong term. If you go into any main stream home audio department and tap on the side of any main stream floor standing speaker, there is a sound that it makes as the side vibrates. The RTA11TL does this too to a lesser degree. This vibration of the cabinet is what I wanted to eliminate figuring it is coloring the sound. Ideally, this vibration should be managed with bracing to firm up the cabinet or with higher density cabinet material. I saw Dynamat as an easier, though less effective, solution.
StanStan
Main 2ch:
HT:
Other stuff:
How about the car?
I should clarify; I meant some easy places to use the rest of it
The metal baskets of the drivers I installed in my truck were already done.
I don't think I have enough to do all 4 door panels though.
Maybe the driver baskets on my RTi10s, if I ever feel like removing them...So, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
Stan
Ok Stan, I've got ya. The issue, as Face pointed out, is the metal skin on the Dynamat will cause more problems than its damping qualities will solve. There is a sound damping material that can be painted on the cabinet walls with no worries about eating up cabinet volume. CP member Decato would be able to provide you with more info on that product.Political Correctness'.........defined
You mean resonance or resonate.
Resonance = box coloration = distortion"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
but using it on the baskets won't cause this? .....or will it?
As long as you're applying it to the back of the baskets, no."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Cool. Thanks! I just ordered a bulk kit."The good thing about science is that it's true whether or not you believe in it." Neil deGrasse Tyson. -
Ok, I'll take your word for it. I am still trying to grasp the mechanics of how the metal skin will cause problems. It was really an experiment anyway.
I'll look into the paint-on stuff or a thin Sonic Barrier like material. I have been meaning to do some more work on the speakers anyway. I want to JB weld the magnets and I might try swapping my XO caps from Clarity Caps to Sonicaps since they are on sale. I can use some of the Clarity Caps in my Monitor 5A's.
So where does this leave us with the FatMat?
StanStan
Main 2ch:
HT:
Other stuff:
