How much space needed for LSi9 Bookshelf Speaker
kprhok
kprhok Posts: 42
I just purchased Polk Audio LSi9 Bookshelf speakers, and am currently building the bookshelves to hold the speakers and other equipment.
I looked at the manual and have info on the proper height, but I am wondering if it makes any difference in quality of sound depending on the distance the rear of a speaker sits away from the wall.
I may want to add an inch or two to the width of the bookshelves IF it makes a big difference in quality of sound. Are there any guidelines on the recommended space a speaker (the back) should be placed away from a wall?
Thanks for your input;)
Post edited by kprhok on
  • cokewithvanilla
    cokewithvanilla Posts: 1,777
    edited July 2010
    I can't speak to the 9's, but I've had the 25's for a while. I was frustrated as hell with them when they were in a small bedroom, then moved to another small bedroom, then moved to an apartment.... lalalala... I finally have them sitting in the large room 8 feet apart, 10 feet from seating area with 4-5 feet of space on either side and 3 feet from the walls...
    now they sound much better.
    I have a feeling you will find that the more room you give them, the better.
  • quadzilla
    quadzilla Posts: 1,543
    edited July 2010
    Typically, the closer to a wall a speaker is, the more bass response will be heard. Try moving the speakers a few inches from the wall at a time and listen. When you like what you hear, stop.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • kprhok
    kprhok Posts: 42
    edited July 2010
