car speaker wire and home speaker wire are the same right?
SivaNevets
Front: Martinlogan ESL
Center: Martinlogan Stage
Rear: Martinlogan Motion 4
Sub: Martinlogan Grotto-I
Receiver: Pioneer Elite SC 1523K
PC 2 Channel: Polk LSI7
Headset: Grado RS2 + Grado RA1 amp
Mic: Neumann KMS605
Car Audio
2002 MB C240 Sedan
MM6501 components
MM840 sub
MB Quart Onyx 4.60 (1/2 to components, 3/4 bridged to sub)
Pioneer 8200BT HU
Mic: Neumann KMS605
Car Audio
2002 MB C240 Sedan
MM6501 components
MM840 sub
Pioneer 8200BT HU
Post edited by SivaNevets on
I had an extra MIT terminator cable that I decided to toss in the back for my subwoofer (amp sits just feet away from the sub) and it works perfectly fine.
-FreddyTruck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
Provided you are part of the wire is wire crowd - Yes.
If you believe there is a difference in sound between different wires - No.Mains.............Polk LSi15 (Cherry)
I find coat hangers work just as well in autosound applications:eek:;):p...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
nooshinjohn wrote: »I find coat hangers work just as well in autosound applications:eek:;):p...
Good for you. Sounds like you have great ears. Did you hear a difference between the plastic coated ones and the ones without the coating? Oh! I hope you ran the coat hangars over those eclectic plastic cable raisers? :rolleyes:;)
I can hear a difference when I adjust the TA on my drivers by 0.04ms, but gosh darn I can't hear the difference between Stinger and Scosche RCA's and I can't hear the difference between kicker and Pear Comice speaker cables. Must be a case of bad ears. :rolleyes:
You need to hear a good 'autosound application'. Only problem is, that maybe 1 in 10,000 installs will qualify as good. But you have to hear one to know what 'good' in a car can mean. Most of you 2 ch guys just don't know what is possible in a car. I guess that's ok, as not all car audio guys know either
Anything in a car that does not go BOOM BOOM BOOM is excellent. Any car that does go BOOM BOOM BOOM should have the owner locked up for life. One strike and you are out. No mercy.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Yeah agree. Mercifully this forum is not about BOOM BOOM.
I used to install autosound gear back in the day, so yes, I have heard some damn good stuff. After you have been car-jacked a couple times for your mobile tune display, it tends to not matter any more.:mad:
A good system is a work of art and I do appreciate it. Some pictures of yours would be nice.:)The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
The install itself is quite basic and fugley
. The driver placement is right though, as I hope is the tuning. It's really about the way it sounds.
Back when you were installing, what would you install if someone asked for pure sq with say a $ 3,000 budget? What equipment would you install and where would you install the stuff? Just curious
Yeah getting car jacked wouldn't be any fun.
