car speaker wire and home speaker wire are the same right?
SivaNevets
SivaNevets Posts: 303
edited July 2010 in Car Audio & Electronics
:confused: i can get some belkin 16 gauge home theatre cable for very cheap. but need to confirm on this
:confused:
Front: Martinlogan ESL
Center: Martinlogan Stage
Rear: Martinlogan Motion 4
Sub: Martinlogan Grotto-I
Receiver: Pioneer Elite SC 1523K
PC 2 Channel: Polk LSI7
Headset: Grado RS2 + Grado RA1 amp
Mic: Neumann KMS605
Car Audio
2002 MB C240 Sedan
MM6501 components
MM840 sub
MB Quart Onyx 4.60 (1/2 to components, 3/4 bridged to sub)
Pioneer 8200BT HU
Post edited by SivaNevets on
  • kawizx9r
    kawizx9r Posts: 5,150
    edited July 2010
    I had an extra MIT terminator cable that I decided to toss in the back for my subwoofer (amp sits just feet away from the sub) and it works perfectly fine.
    -Freddy
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • McLoki
    McLoki Posts: 5,231
    edited July 2010
    Provided you are part of the wire is wire crowd - Yes.
    If you believe there is a difference in sound between different wires - No.
    nooshinjohn Posts: 26,064
    edited July 2010
    I find coat hangers work just as well in autosound applications:eek:;):p...
  • arun1963
    arun1963 Posts: 1,797
    edited July 2010
    Good for you. Sounds like you have great ears. Did you hear a difference between the plastic coated ones and the ones without the coating? Oh! I hope you ran the coat hangars over those eclectic plastic cable raisers? :rolleyes:;)
    I can hear a difference when I adjust the TA on my drivers by 0.04ms, but gosh darn I can't hear the difference between Stinger and Scosche RCA's and I can't hear the difference between kicker and Pear Comice speaker cables. Must be a case of bad ears. :rolleyes:
    You need to hear a good 'autosound application'. Only problem is, that maybe 1 in 10,000 installs will qualify as good. But you have to hear one to know what 'good' in a car can mean. Most of you 2 ch guys just don't know what is possible in a car. I guess that's ok, as not all car audio guys know either :).
  • BlueFox
    BlueFox Posts: 15,250
    edited July 2010
    Anything in a car that does not go BOOM BOOM BOOM is excellent. Any car that does go BOOM BOOM BOOM should have the owner locked up for life. One strike and you are out. No mercy.
  • arun1963
    edited July 2010
    Yeah agree. Mercifully this forum is not about BOOM BOOM. :)
    edited July 2010
    arun1963 wrote: »
    I used to install autosound gear back in the day, so yes, I have heard some damn good stuff. After you have been car-jacked a couple times for your mobile tune display, it tends to not matter any more.:mad:
    A good system is a work of art and I do appreciate it. Some pictures of yours would be nice.:)
  • arun1963
    edited July 2010
    The install itself is quite basic and fugley :o. The driver placement is right though, as I hope is the tuning. It's really about the way it sounds.
    Back when you were installing, what would you install if someone asked for pure sq with say a $ 3,000 budget? What equipment would you install and where would you install the stuff? Just curious
    Yeah getting car jacked wouldn't be any fun.
