Adcom GFA-5800 2 ch amplifier for sale in NJ
devani
devani Posts: 1,497
edited December 2010 in For Sale (FS) Classifieds
I have the Adcom GFA-5800 Amp for sale.
I prefer local buyer and give perference to local buyers first. I also have the box for it. No manuals. Can be used with SDA by negative terminals grounded together...
8/10 condition.....located in 07885 NJ for pick up and hooked up to Monitor 10 A for demo. Too much of an amp for me....thanks...
$550
more info on the amp
Adcom GFA-5800 (Nelson Pass Design)
The GFA-5800 is unlike most amplifiers as it uses only MOSFET's in the signal path. NO bipolar transistors anywhere.
It also simplifies the signal path by using only three gain stages.
Built-in Bi-wire capability
250 + 250 watts RMS into 8-ohms from 20-20,000-Hz @ 0.18% THD
400 + 400 watts RMS into 4-ohms from 20-20,000-Hz @ 0.18% THD
Freq. Response: 10-20,000Hz [+0/-.25 dB]
Power Bandwidth: 3-130,000Hz (-3dB)
Dynamic Headroom @ 4-ohms: 2.1dB
IM Distortion: (CCIF 4kHz-20kHz) 100dB
Damping Factor from 20-20,000Hz: > 1100 (incredible!)
Gain: Unbalanced (29dB), Balanced (26dB)
Dimensions: 17" W x 8" H x 13.5" D
Weight 62 lbs
Video: LG 55LN5100/Samsung LNT4065F
Receiver: HK AVR445
Source: OPPO BDP-93
HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83
Post edited by devani on
  • John in MA
    John in MA Posts: 1,010
    edited July 2010
    I have one of these I've been trying to sort out for years. Any idea what the mode of operation for the fans is actually supposed to be? Most owners I've talked to have similar malfunctions to mine.
  • devani
    devani Posts: 1,497
    edited July 2010
    john,
    No I don't. but it sure looks simple enough to figure out if I had Pspice on my computer.....previous work place had it and would have run a simulation with LM317....
    Receiver: HK AVR445
    Source: OPPO BDP-93
  • audiobilly
    audiobilly Posts: 351
    edited July 2010
    If this in the realm of what you are talking about. If the unit does not come with fans. I am not familiar
    with the 5800, yet.
    What about AC powered fans after the main Power switch? Lots of places to come out of the amp, some nice grommets, little mounting hardware, you are good to go. Get the correct size and CFM. High cfm fans can be noisy, some experimenting may be necessary.
    I have two GFA-5500 that I have done this on, works great!
    heiney9 Posts: 25,496
    edited July 2010
    John in MA wrote: »
    NM................this is a FS thread don't want to muck it up. John in MA I'll PM you.
  • devani
    devani Posts: 1,497
    edited July 2010
    $520.......bump~
    Receiver: HK AVR445
    Source: OPPO BDP-93
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited July 2010
    WOOOOOW That would rock a set of LSi25's
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • dpowell
    dpowell Posts: 3,081
    edited July 2010
    This amp is a powerhouse! Good luck with the sale.
  • devani
    devani Posts: 1,497
    edited August 2010
    another bump with new price $500.....
    anyone want this shipped??
    Receiver: HK AVR445
    Source: OPPO BDP-93
  • devani
    devani Posts: 1,497
    edited August 2010
    I can bring the amp to the Polkfest if anyone is interested....
    also I can ship the amp if shipping is paid...
    Receiver: HK AVR445
    Source: OPPO BDP-93
  • devani
    devani Posts: 1,497
    edited September 2010
    new price bump! $480
    Receiver: HK AVR445
    Source: OPPO BDP-93
  • kevhed72
    kevhed72 Posts: 5,160
    Man, that is a great price. If this was for sale before I bought my Parasound, I would have bought it in a minute....:)
  • steelervic
    steelervic Posts: 142
    i have had and compared the 5800 with the 5500, 555, 555II, 5802. i still have the 5800 and have sold the rest.
    john, the fans come on at different temperatures, one when it starts getting warm and the other when it gets warmer. i measured them, but can't recall the temps. i also measured the temp of the 5500 and 5802, the 5800 ran cooler than both because of the fans.
    the 5800 is a great amp, at that price your giving it away. if i could, i would have bought it when you first listed it. i highly advice you if at all finacially possible to keep it before selling at that price.
    vic
  • devani
    devani Posts: 1,497
    thanks vic and sal, I can bring the amp to the Polkfest if anyone is interested....
    original box is included in the price...$480 for excellent condition Adcom amp
    Receiver: HK AVR445
    Source: OPPO BDP-93
  • Lietuvis91
    Lietuvis91 Posts: 909
    Kim wrote: »
    If you look at the schematic there are two different values for the thermal switches that turn on the fans. The left side uses a 60 C switch, and the right side uses a 40 C.
    Why two different values, I don't know...
    could it be because the second fan only comes on if the first one cannot handle the duty of keeping the temps to a reasonable level? If you're not pushing the amp hard enough there is no reason for the second fan to come on and therefore it doesn't?! Just a thought...
    I'm thinking of that becuase the fans in your car have 2 settings, hi and low, the fan comes on at a low setting at 180F and switches to high at 215F. It's a similar concept.
    Living Room 7.1 HT Rig:
    M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
    Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
    LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3
  • steelervic
  • steelervic
    and because of the fans, it stays cooler than the 5500 or the 5802.
    The reason the fans are used is because the heat sinks are enclosed. The 5802 has the heatsinks in open air.
    The amps are similar with the 5802 getting the edge in sound and design. This is a great deal for a very nice amp.
  • steelervic
    i compared the 5802 and 5800 side by side, same everything, i couldn't hear a difference. it seems like using the fans may be a better design, as the 5800 stays cooler than the 5802.
    steelervic wrote: »
    Some designs are designed to run hotter so I don't buy that. Sure overheating is never a good thing, but a high bias A/B amp should get warm to very warm and a single ended Class A will get hot enough to make morning eggs.
    If the parts and design are good enough then running warm to hot isn't bad, it's necessary. In this case since the heatsinks are internal Adcom felt fans were needed for proper cooling.
    The 5802 doesn't need fans for cooling.
  • devani
    devani Posts: 1,497
    possible sale bump!
    Receiver: HK AVR445
    Source: OPPO BDP-93
  • devani
    devani Posts: 1,497
    still open to all buyers....
    Receiver: HK AVR445
    Source: OPPO BDP-93
  • Earthy
    Earthy Posts: 488
    It's a heck of a deal too.
    Polk Audio SDA SRS 2.3TL
    Parasound Halo A21
    Parasound Halo P3
    Home theater
    Polk LSiM 707, 706c, 703, 705
    Polk Blackstone TL3 for height
    SVS PB12-ISD Sub
    Denon AVR-X6400h
    Parasound Halo A51
    LG OLED65B7A
    Sony UBPX800
    Logitech Harmony Elite
    PC LSiM 703
    Spare LSIM 702 and 706c
    Home Theater #2
    Polk Audio LS70, CS350LS, LSF/X, S4
    Onkyo TX-NR808
  • infinity man
    infinity man Posts: 5
    interested in buying adcom amp.
    devani wrote: »
  • infinity man
    I live in New Jersey interesed in adcom,will also pick up
  • bigaudiofanatic
    Trades?
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • infinity man
    Trades?
    are u selling the adcom if so I'm willing to pick up.
  • infinity man
    I am trying to find out if the person selling the adcom 5800 is for real willing to buy & can pick up.
  • cstmar01
    cstmar01 Posts: 4,424
    I think we get the idea you are interested. However it would probably be better to send him a PM or email as it doesn't look like he's responding to your posts.
  • devani
    devani Posts: 1,497
    I am real :D and have made several transactions here.....sent you a PM....
    Receiver: HK AVR445
    Source: OPPO BDP-93
  • devani
    devani Posts: 1,497
    I have received your PM and I want to chew on this for a few days. I was surprised to see your offer lower than the my asking price but not by much....
    Thanks...
    Receiver: HK AVR445
    Source: OPPO BDP-93
