Adcom GFA-5800 2 ch amplifier for sale in NJ
devani
I have the Adcom GFA-5800 Amp for sale.
I prefer local buyer and give perference to local buyers first. I also have the box for it. No manuals. Can be used with SDA by negative terminals grounded together...
8/10 condition.....located in 07885 NJ for pick up and hooked up to Monitor 10 A for demo. Too much of an amp for me....thanks...
$550
more info on the amp
Adcom GFA-5800 (Nelson Pass Design)
The GFA-5800 is unlike most amplifiers as it uses only MOSFET's in the signal path. NO bipolar transistors anywhere.
It also simplifies the signal path by using only three gain stages.
Built-in Bi-wire capability
250 + 250 watts RMS into 8-ohms from 20-20,000-Hz @ 0.18% THD
400 + 400 watts RMS into 4-ohms from 20-20,000-Hz @ 0.18% THD
Freq. Response: 10-20,000Hz [+0/-.25 dB]
Power Bandwidth: 3-130,000Hz (-3dB)
Dynamic Headroom @ 4-ohms: 2.1dB
IM Distortion: (CCIF 4kHz-20kHz) 100dB
Damping Factor from 20-20,000Hz: > 1100 (incredible!)
Gain: Unbalanced (29dB), Balanced (26dB)
Dimensions: 17" W x 8" H x 13.5" D
Weight 62 lbs
$550
Weight 62 lbs
Video: LG 55LN5100/Samsung LNT4065F
Receiver: HK AVR445
Source: OPPO BDP-93
HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83
Receiver: HK AVR445
Source: OPPO BDP-93
Post edited by devani on
I have one of these I've been trying to sort out for years. Any idea what the mode of operation for the fans is actually supposed to be? Most owners I've talked to have similar malfunctions to mine.
john,
No I don't. but it sure looks simple enough to figure out if I had Pspice on my computer.....previous work place had it and would have run a simulation with LM317....Video: LG 55LN5100/Samsung LNT4065F
Receiver: HK AVR445
Source: OPPO BDP-93
2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83 -
If this in the realm of what you are talking about. If the unit does not come with fans. I am not familiar
with the 5800, yet.
What about AC powered fans after the main Power switch? Lots of places to come out of the amp, some nice grommets, little mounting hardware, you are good to go. Get the correct size and CFM. High cfm fans can be noisy, some experimenting may be necessary.
I have two GFA-5500 that I have done this on, works great! -
John in MA wrote: »I have one of these I've been trying to sort out for years. Any idea what the mode of operation for the fans is actually supposed to be? Most owners I've talked to have similar malfunctions to mine.
NM................this is a FS thread don't want to muck it up. John in MA I'll PM you.
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
$520.......bump~Video: LG 55LN5100/Samsung LNT4065F
Receiver: HK AVR445
Source: OPPO BDP-93
WOOOOOW That would rock a set of LSi25'sHT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
This amp is a powerhouse! Good luck with the sale.____________________________________________________________
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, Pass Labs X1, Marantz 7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Moon 380D DAC, EPSON Pro Cinema 6050 -
another bump with new price $500.....
anyone want this shipped??Video: LG 55LN5100/Samsung LNT4065F
Receiver: HK AVR445
Source: OPPO BDP-93
I can bring the amp to the Polkfest if anyone is interested....
also I can ship the amp if shipping is paid...Video: LG 55LN5100/Samsung LNT4065F
Receiver: HK AVR445
Source: OPPO BDP-93
new price bump! $480Video: LG 55LN5100/Samsung LNT4065F
Receiver: HK AVR445
Source: OPPO BDP-93
Man, that is a great price. If this was for sale before I bought my Parasound, I would have bought it in a minute....:)
i have had and compared the 5800 with the 5500, 555, 555II, 5802. i still have the 5800 and have sold the rest.
john, the fans come on at different temperatures, one when it starts getting warm and the other when it gets warmer. i measured them, but can't recall the temps. i also measured the temp of the 5500 and 5802, the 5800 ran cooler than both because of the fans.
the 5800 is a great amp, at that price your giving it away. if i could, i would have bought it when you first listed it. i highly advice you if at all finacially possible to keep it before selling at that price.
vic -
thanks vic and sal, I can bring the amp to the Polkfest if anyone is interested....
original box is included in the price...$480 for excellent condition Adcom ampVideo: LG 55LN5100/Samsung LNT4065F
Receiver: HK AVR445
Source: OPPO BDP-93
If you look at the schematic there are two different values for the thermal switches that turn on the fans. The left side uses a 60 C switch, and the right side uses a 40 C.
Why two different values, I don't know...
could it be because the second fan only comes on if the first one cannot handle the duty of keeping the temps to a reasonable level? If you're not pushing the amp hard enough there is no reason for the second fan to come on and therefore it doesn't?! Just a thought...
I'm thinking of that becuase the fans in your car have 2 settings, hi and low, the fan comes on at a low setting at 180F and switches to high at 215F. It's a similar concept.Living Room 7.1 HT Rig:
M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3 -
thats correct
and because of the fans, it stays cooler than the 5500 or the 5802.
The reason the fans are used is because the heat sinks are enclosed. The 5802 has the heatsinks in open air.
The amps are similar with the 5802 getting the edge in sound and design. This is a great deal for a very nice amp."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
i compared the 5802 and 5800 side by side, same everything, i couldn't hear a difference. it seems like using the fans may be a better design, as the 5800 stays cooler than the 5802.
steelervic wrote: »i compared the 5802 and 5800 side by side, same everything, i couldn't hear a difference. it seems like using the fans may be a better design, as the 5800 stays cooler than the 5802.
Some designs are designed to run hotter so I don't buy that. Sure overheating is never a good thing, but a high bias A/B amp should get warm to very warm and a single ended Class A will get hot enough to make morning eggs.
If the parts and design are good enough then running warm to hot isn't bad, it's necessary. In this case since the heatsinks are internal Adcom felt fans were needed for proper cooling.
The 5802 doesn't need fans for cooling.
possible sale bump!Video: LG 55LN5100/Samsung LNT4065F
Receiver: HK AVR445
Source: OPPO BDP-93
still open to all buyers....Video: LG 55LN5100/Samsung LNT4065F
Receiver: HK AVR445
Source: OPPO BDP-93
It's a heck of a deal too.Polk Audio SDA SRS 2.3TL
Parasound Halo A21
Parasound Halo P3
Home theater
Polk LSiM 707, 706c, 703, 705
Polk Blackstone TL3 for height
SVS PB12-ISD Sub
Denon AVR-X6400h
Parasound Halo A51
LG OLED65B7A
Sony UBPX800
Logitech Harmony Elite
PC LSiM 703
Spare LSIM 702 and 706c
Home Theater #2
Polk Audio LS70, CS350LS, LSF/X, S4
Onkyo TX-NR808 -
I live in New Jersey interesed in adcom,will also pick up
Trades?HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
bigaudiofanatic wrote: »Trades?
infinity man wrote: »are u selling the adcom if so I'm willing to pick up.
infinity man wrote: »I am trying to find out if the person selling the adcom 5800 is for real willing to buy & can pick up.
I think we get the idea you are interested. However it would probably be better to send him a PM or email as it doesn't look like he's responding to your posts. -
I am real and have made several transactions here.....sent you a PM....Video: LG 55LN5100/Samsung LNT4065F
Receiver: HK AVR445
Source: OPPO BDP-93
I have received your PM and I want to chew on this for a few days. I was surprised to see your offer lower than the my asking price but not by much....
Thanks...Video: LG 55LN5100/Samsung LNT4065F
Receiver: HK AVR445
Source: OPPO BDP-93
