Polk PSW 303 popping from tapping and humming from touching?!
Hertz
Hi ya'll, I just bought an other-wise good-great condition Polk PSW-303. It sounds great, except it will POP when nothing is going to it, or when I tap the enclosure! Really disgruntling. Also, when I touch the 180 degree switch I get a medium volume hum, but when I touch the incoming cable and it at the same time the hum is "eliminated." (there's still amp noise, too :mad:) ALSO, when there is NO incoming signal cable and I touch said switch, the hum is a good FIVE TIMES LOUDER AND DEEPER! As if I'm playing a 40Hz sine wave!
It's also NOT a "pushing it too hard" thing at ALL because of, well, not only what I just explained but also because if I play a sine wave all is well, until I play 30Hz, then all goes to hell, BUT if I turn it UP LOUDER, to MAX volume, the popping becomes less of an occurrence.
It's almost like a a mixture of a *SEVERE* ground loop and a loose cable/bad capacitor/loose transformer inside?
Any ideas people?!
Any ideas people?!
Post edited by Hertz on
ANYbody?!
Well, I'm not thinking that sub is going to play 30Hz very well. It's rated to 28, but the -3dB limit is 35... I can get most of my subs to hum by wiggling the cable or perhaps touching the amp or a knob. If it's not doing what you want it to do, I'd get another sub that will.
No, it does EVERYTHING I want it to do, and it plays 30Hz DAMN well, and it even makes 20Hz very noticeable, however it's simply MALFUNCTIONING. The sub POPS like pop-rocks when I simply move the unit and/or tap the box when there's a signal coming into the L/R/LFE ports on the back.
That's it. Oh, low frequency hum when I touch the polarity switch w/o a cable plugged into the back. -
Umm, then how about not moving it or touching it then? Sounds like a short or something like a little corrosion somewhere. Could be the cable; could be internal. I'm sure that touching the switch with it unplugged is a ground loop effect. I don't think that's much to worry about, not do I think it's related to the popping. I'm surprised that sub can play 20Hz. -
Right, it really only happens when I tap it, BUT IT'S STILL A PROBLEM I WANT TO SOLVE!
Could it be damaging the woofer do you think? Corrosion would be bad, too.
Damn.
