Overpowering LSi7s?
DVOuSS
DVOuSS Posts: 52
edited July 2010 in Speakers
I just picked up a XPA-5 for the low low price of $500. I use it to power my Lsi25s and LSi7s for the surrounds. I know the LSi25s will handle the 300 watts per channel, will the LSi7s?
Living Room
Toshiba 55" 240HZ LCD
Onkyo TX-NR807
Emotiva XPA-5
HTPC
Polk Audio LSi 25 - Mains
Polk Audio LSiC - Center
Polk Audio LSi 9 - Surrounds
DSW microPRO 4000 x2 - Subs
Media Room
Mitsubishi 73" DLP
Onkyo TX-SR875
HTPC
2 x JBL Urei S300 Amplifiers
2 x JBL Urei S150 Amplifiers
JBL Synthesis Three S3M - Mains
JBL Synthesis Three S3HC - Center
JBL Synthesis Three S3S - Subs
JBL Synthesis Two S2A - Surrounds
Post edited by DVOuSS on
  • dane_peterson
    dane_peterson Posts: 1,903
    edited July 2010
    You are far from overpowering any LSi with that AMP...
  • McLoki
    McLoki Posts: 5,231
    edited July 2010
    I run my rear LSi7's from my Cinepro with no problems. I am sure you will be fine.
    Michael
  • DVOuSS
    DVOuSS Posts: 52
    edited July 2010
    awesome thanks...
    Living Room
    Onkyo TX-NR807
    Emotiva XPA-5
    HTPC
    Media Room
    Mitsubishi 73" DLP
    Onkyo TX-SR875
    HTPC
  • cfrizz
    cfrizz Posts: 13,415
    edited July 2010
    Welcome to Club Polk DV, and enjoy your system.
    nooshinjohn Posts: 26,001
    edited July 2010
    you are far from overpowering any lsi with that amp...
    lmao!!! :D
  • DVOuSS
    DVOuSS Posts: 52
    edited July 2010
    yeah i got a pretty good kick out of that too...i let it go...but what i am trying to figure out...and im no audiophile...but if the lsi7s are rated to 200 watts max...and the XPA-5 delivers 300WPC RMS...how is it hard to believe that I might think that this amp could damage the 7s?
    Living Room
    Onkyo TX-NR807
    Emotiva XPA-5
    HTPC
    Media Room
    Mitsubishi 73" DLP
    Onkyo TX-SR875
    HTPC
  • cheddar
    cheddar Posts: 2,390
    edited July 2010
    Damage to speakers occurs when an amplifier loses control of the signal and sends distortion to the speakers, usually frying the tweeters in the process. This happens when an amp is not powerful enough to keep up with the demands of the source at a given volume level. So an amp rated at 25 watts reaching its limit is far more likely to damage a speaker than a 300 watt amp with room to spare.
    That said, just because an amp is rated at 300 watts doesn't mean that it ever really gets that high. Unless you're trying to fill an extremely large room with sound or you have really difficult to drive speakers (far beyond the 4ohm LSis) you will likely never reach an average 100 watts per channel during normal listening without risking serious injury to your hearing. You can get a lot of volume on even 15 watts per channel.
  • DVOuSS
    DVOuSS Posts: 52
    edited July 2010
    that was very informative, and if i recall i had read something along those lines a few times here in the polk forum before...thanks for your help
    Living Room
    Onkyo TX-NR807
    Emotiva XPA-5
    HTPC
    Media Room
    Mitsubishi 73" DLP
    Onkyo TX-SR875
    HTPC
