which gauge speaker wire do you recommend?
ECGnovice
ECGnovice Posts: 31
Posts: 4 subwoofer: pws125 vs infinity PS212
Hi All:
I have purchased RC80is as my front wall speakers in my 2nd home theater setup in my 900 ft basemen. I also went with a CS20 as my central channel and the Infinity PS212 as a subwoofer.
Which gauge speaker wire would you recommend I go with. 12 gauge or 14? Will I notice the difference?
Thanks,
A novice
Post edited by ECGnovice on
  • nduitch
    nduitch Posts: 316
    edited July 2010
    If it going in the wall, then in-wall wire. If not, then 16au if fine.
  • ECGnovice
    ECGnovice Posts: 31
    edited July 2010
    Thank you. my installer has in wall wire plus speaker wire for the central channel and the sub. I assume the lower the number 16,14, 12 the better the wire? If so, I guess you mean that 16 is sufficient.
  • thuffman03
    thuffman03 Posts: 1,325
    edited July 2010
    I would try different guages and see what sounds best to you. Some like really thin while others like thick. It will change the the sound going from thin to thick.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
