Dolby®/DTS TrueHD
acmf74
acmf74 Posts: 937
Currently I'm listening to my movies through a Digital coaxial and TrueHD is only available though HDMI. Does TrueHD sound that much better?
Post edited by acmf74 on
  • cstmar01
    cstmar01 Posts: 4,424
    edited July 2010
    IMO yes it does sound better. how much better can only be determined by you though, for me it makes a big difference and I prefer the lossless formats over the others any day.
  • vc69
    vc69 Posts: 2,500
    edited July 2010
    Of course, it depends on the resolution of your HT, but I would offer a resounding "Yes".
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • thuffman03
    thuffman03 Posts: 1,325
    edited July 2010
    I cannot say that I hear much of a difference between any of the DD or DTS formats. IMO it is a lot of hype just like getting a THX lable on your amp.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • danger boy
    danger boy Posts: 15,722
    edited July 2010
    acmf74 wrote: »
    simple put, yes it does.
    PolkFest 2012, who's going>?
  • vc69
    vc69 Posts: 2,500
    edited July 2010
    Keiko wrote: »
    Look at it this way: DTS TrueHD is what SACD is to an mp3. So what you're getting now is a compressed audio track. DTS TrueHD is lossless and much more dynamic in terms of audio reproduction.
    Eggs ackly!
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • kuntasensei
    kuntasensei Posts: 3,263
    edited July 2010
    Just to avoid confusion... It's Dolby TrueHD and DTS Master Audio. But Keiko's comparison is spot on.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • kawizx9r
    kawizx9r Posts: 5,150
    edited July 2010
    thuffman03 wrote: »
    With the older formats, DD was slightly more compressed iirc compared to DTS.
    As for the new Dolby TrueHD and Master DTS, yeah they're much better than the older DD and DTS formats.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • Ric5811
    Ric5811 Posts: 400
    edited July 2010
    acmf74 wrote: »
    Well, you can get it through analog outputs also, if your transport has them.
    Polk RTi A7's FrontPolk CSi A4 CenterPolk Tsi 100's SurroundOnkyo TX-RZ50:)Oppo BDP 83 (Collecting dust)MIT Terminator 3 Speaker CableMIT Terminator 2 IC's (Oppo 2 chan)Signal Cable HT TWOEpson PowerLite Home Cinema 1080Hisense 55 U8GBelkin PF 60 Power Center
  • BlueFox
    BlueFox Posts: 15,250
    edited July 2010
    It is fantastic. There is no contest in this comparison. Go lossless via HDMI.
    I have noticed with BluRay they make much better use of the surround speakers than with the compressed sound on DVDs. If someone says they cannot hear a difference between compressed regular DVD and lossless BR they are either deaf, or have low-end gear.
  • thuffman03
    edited July 2010
    kawizx9r wrote: »
    This is most likely true but I don't watch enough movies to warrent upgrading at this time.
    Years ago I was upgrading my AVR every time a new format came out. First it was D Prologic, then DD, then DTS. Now I have a DD/DTS DVD system and I will wait till I am almost forced to go to the next level. Something in my system has to die or DVD's are no longer available.
    I am tired of chasing the technology upgrade game they want you to play. Too much money spent on something I use once or twice a week.
  • acmf74
    acmf74 Posts: 937
    edited July 2010
    thanks....all
    I guess if/when I decided to upgrade I will look at a new reciever that can process the HD signal and 4ohm.
  • ECGnovice
    ECGnovice Posts: 31
    edited July 2010
    can you please tell me what is the difference between prologic and DTs?
