What is the difference between diagnosing and troubleshooting in computers?
peterjack
I know that these two were generally connected but there must be at least a difference or a specific difference between the two. That is what i want to know. Can you please help me explain this matter? Thanks a lot for your ideas.
Post edited by peterjack on
It's the same thing. Are you thinking maybe of running a diagnostic? That's software that tests the system and is used as a step in trouble shooting.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
the easiest way that i know to explain it is that diagnosing is determining what is the problem and troubleshooting is working to fix the problem. Hope that helps.
Oh yeah, Welcome to the CP.Front - RTiA5's
Rear - RTiA3's
Center - CSiA4
Sub - PSW110 -
Diagnosing is figuring out what is causing the trouble.
Trouble shooting is when your computer has trouble and you take it out in the back yard and shoot it.Stan
Main 2ch:
HT:
Other stuff:
you troubleshoot to obtain a diagnosis
packetjones is correct. skrol is also correct in a funnier manner.Speaker: LSi 15
Pre/Pro: Pioneer VSX-9040
Amp: Emotiva XPA-2
Sub: Seaton Submersive HP
TV: Samsung PN50B550
DAC: soon-to-be EE Minimax Dac Plus -
Diagnosing is when you figured out what the problem is and Troubleshooting is what you do to Diagnose a problem.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
