Musica Bella Basis plus +
W WALDECKER
I recieved this 6SN7 based linestage three days ago from Bill Baker @ Response Audio, it uses a toroidal transformer with big metalized poly caps in the power supply and Fairchild ultra fast soft recovery diodes in the rectifier bridge. the signal path uses Clarity caps bypassed with V-Cap teflons.there are no electrolytic capacitors used anywhere in this preamplifier. all input and output RCA's are Cardas and the stepped volume control uses 1% Dale/Vishay resistors. all internal wiring is solid copper/teflon.i ordered it with three sets of inputs and two sets of outputs.Bill put pictures of my preamplifier on the Audiocirle and here is one of them
Bill does beautiful work in wood but i opted for a basic Aluminum Chassis . Bill said he had 100 hrs on the caps after he built it and i have about 30 hrs on it so the V-caps will require several hundred more hrs to fully settle in. it sounds very sweet already. life is good....WCW III
Bill does beautiful work in wood but i opted for a basic Aluminum Chassis . Bill said he had 100 hrs on the caps after he built it and i have about 30 hrs on it so the V-caps will require several hundred more hrs to fully settle in. it sounds very sweet already. life is good....WCW III Rogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
.Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers.
Post edited by W WALDECKER on
nice pre WCW,,enjoy--good to hear that things are going well--how are the children?JC approves....he told me so. (F-1 nut)
Hey George, Happy 4th of July to you and your family! the "Baby Girl" Courtney Ann who is now age 14 is spoiled rotten as usual.i am getting ready to have a cook out down here on the waterfront and watch the fireworks after dark. thanks....WCW IIIgeorge daniel wrote: »nice pre WCW,,enjoy--good to hear that things are going well--how are the children?Rogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
Very nice. How much did that run you if you don't mind me asking.
Expect the V-Caps to take about 400 hours to settle.
Congrats and enjoy!"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
the wooden Basis plus retails for just under 2 grand and the upgraded internal wiring and V-Cap bypass which are standard in the Basis Silver Extreme were added to mine at my request and were done at additional cost. I bought mine while Bill was running a sale last month. i believe i have around $1500.00 in itVery nice. How much did that run you if you don't mind me asking.
I had .22uf V-caps in a BAT VK60 in the coupling positions and it took a little over 400 hrs to settle inExpect the V-Caps to take about 400 hours to settle.
Congrats and enjoy!
