New binding posts for my SDAs
fbm211
I picked these up on audiogon last week and finally got them.Now Im just waiting on some silicoln to make sure their air tight after I install em.
I hope I dont have to remove the PRs to install these since I already did the moretite mod.:eek:
SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
Post edited by fbm211 on
Congratulations on your new binders
I'll be replacing mine on 2B's soon, so will be very interested to hear how your change goes. I went with these. Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com -
Did you get those at sonic craft? Are those cardas?SDA-2BTL with custom IC
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
No they are Vampire Wire BPHEX/CB.
http://www.vampirewire.com/pc-49-16-bphexcb.aspx
The price is for all 4 binders for 2 speakers.Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
Both are excellent posts."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Do not use silicone, it's highly acidic in the curing process. Use hot glue.Political Correctness'.........defined
President of Club Polk -
Got ya,I didnt know that.Ill order a gun and glue today.
Thanks for the heads up.SDA-2BTL with custom IC
Don't order a glue gun,go to wallyworld or ratshack.If you can't hear a difference, don't waste your money.
Vampires are nice but my fav's are Cardas, and they cost less.
While I'm new to all these mods, isn't $125.00 extreme? I don't mind spending the coin, but couldn't one buy an above average post and put the saved funds towards a higher level cap, resistor or any other piece?
Gordon2 Channel -
Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8) -
Gordon, if you think Cardas posts are expensive, price some TOTL WBT's.Political Correctness'.........defined
Damn.I now find out I need to make the binding posts holes bigger in the terminal cups.I will borrow a drill and bits since my dremal doesnt have bits large enough.SDA-2BTL with custom IC
Hey fbm211, could you please take some photos as you do this mod, and post them on here? I'll be changing the binders on a set of SDA 2B's when I get them, and your photos of your project would certainly help me.
Thanks Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
It's a pretty easy process, unscrewing/desoldering the old ones and ****/soldering in the new ones. However as posted above, I've had to open up the mounting hold a little on all the Polk speakers I've installed new posts on.
TOOLFORLIFEFAN wrote: »Vampires are nice but my fav's are Cardas, and they cost less.
I'm not sure who you're buying them from....you can usually find them both within a $1.50 of one another depending on where you get them. There's zero sonic difference so buy what's cheaper. Both are excellent upgrades to the brittle plastic, stock binders.
www.vampirewire.com
I've also not had to modify the holes for Vampire's(BP-HEX)....as someone mentioned that previously. They are drop in replacements.
WBT is horribly overpriced.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
I will take some pics of mine installed tonight..
www.vampirewire.com
Killer site doro.Very fair prices too.
Nice bananas.SDA-2BTL with custom IC
The UPS driver didnt leave the sonic craft order at my door today.I cant replace the IC posts till I get that box with all the goodies in it.
Pics of some progress later perhaps.SDA-2BTL with custom IC
Its only waiting on the cardas pure copper posts from sonic craft:DSDA-2BTL with custom IC
Pretty easy.Now to strip and bare the wire and solder to the Pods.:eek:.ETI reccomends I put a banana plug in the one Im soldering to act as a heat sink to protect the plastic..
One wonders if I should replace the stock wire with some neoteck 14 gauge teflon copper.I think from posts to xover a 14 gauge is fine but the wires going from xover to drivers should remain the same gauge which I think is 18?????SDA-2BTL with custom IC
Look at those old posts.Are they made of steel or nickel.??:mad:SDA-2BTL with custom IC
These pics are in my 1.2tl upgrade thread as well, You can see I added a 1/4" thick piece of delrin to the back of the cups for extra support when I tightened them down.
stopped in my tracks.I need more power --watts-- .Had to order a weller therma boost gun which should do the job.
The 25watt and even a 60 watt I had but forgot about cant get those posts hot enough to get a good solder joint.SDA-2BTL with custom IC
Thanks for that information.
Good to know the Vampire BPHEX binders are a drop in replacement. Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
Larry, as usual a beautiful job! Thanks for posting those photos. One thing I had not yet considered doing is upgrading the interconnect. Might as well order one more set of binders to take care of that while I'm at it.Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
MORE POWER!!!
Thanks for posting the photos. So you are replacing the wires from the binding posts to the crossover? Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
Id like to---there is some serious oxidation. And what about the molex plugs? Can I get those anywhere?SDA-2BTL with custom IC
How are you guys getting all of that glue off? Are you just cutting it out or do you melt it and then scrape it off or what?
2-channel
Squeezebox Touch| MSB Analog DAC | Audio Research Ref 40 Anniversary Edition| Pass Labs X350.8 | Wilson Audio Sasha 2
Arcam AVR 550 | GoldenEar Triton One | GoldenEar SuperCenter XXL | GoldenEar Aon 3 | JL Audio Fathom F113v2 -
I use a set of dental picks from Home Depot to pry it off. It's usually so old it comes off very easily and in big pieces.
DO NOT MELT IT....there's no need to do so.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
Hmmm... this makes me want to tweak my own, but I am using the blade/blade version of the IC socket on my SDA SRS Originals, so I think it may be slightly different.
If I were to get the IC socket off (again, the blade/blade version), could I just replace it with a standard binding post and then solder the wires leads inside of the cabinet to the post? I'm a bit confused because there are two wires going to the socket right now (one to each blade), so I don't know what to do with the wires.
I've always wanted to do this, but this is where I get confused and stop!
2-channel
MOLEX PLUGS......ANYONE????
Would old 3 wire plugs---molex---From old PC cables they use from the power supply to the HD for example.Would they work.?
Or can I buy them.Id hate to have to direct solder from posts to xover.SDA-2BTL with custom IC
