Oppo BDP 83 SE problems Bummer
vmaxer
vmaxer Posts: 5,120
edited July 2010 in The Clubhouse
Well, my Oppo BDP 83SE stopped outputting any video at all, nothing:mad: The only reset I see is in the menu....can't get that to work either. Since I have no video output, the only thing I can see is the front display on the Oppo. I can get it to show "setup menu" but nothing else.
Anyone have this happen to them?? Any ideas??:confused:
Long week-end and can't watch movies...I can listen to them:eek:
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
Post edited by vmaxer on
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited July 2010
    You could try reloading the firmware - maybe it got corrupted.
    Do you have the latest from the Oppo website downloaded to a USB thumbdrive?
  • vmaxer
    vmaxer Posts: 5,120
    edited July 2010
    Erik Tracy wrote: »
    I usually do it via the network connection, but I wll download it and try it a bit later...Working in the yard at the moment.
    Thanks for the suggestion!!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vmaxer
    vmaxer Posts: 5,120
    edited July 2010
    Well, I backed up one version on the firmware...no change at all:mad:
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    Toolfan66 Posts: 17,999
    edited July 2010
    Have you tried swapping out your HDMI cable? It's a long shot I know but you never know..
  • snow
    snow Posts: 4,358
    edited July 2010
    It may sound silly but unplug it from the wall wait 30 secs and plug it back in.
    REGARDS SNOW
  • vmaxer
    vmaxer Posts: 5,120
    edited July 2010
    I am using component video cables, doubt all three would go out at once??
    snow wrote: »
    REGARDS SNOW
    Yep...tried that.
    I can't seem to find a way to do a hard reset, but the firmware change did nothing either...I guess I will have to wait and send it back...:confused:
    I
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • kuntasensei
    kuntasensei Posts: 3,263
    edited July 2010
    Press and hold the DISPLAY button for 10-15 seconds. When you release it, it should reset your video options to their defaults. That might get you going again. If it does, install the latest firmware, then do the reset to defaults in the menu, then clear persistent storage and plug in all your video options again.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • vmaxer
    vmaxer Posts: 5,120
    edited July 2010
    Thanks, but no effect at all.....
    Just not my day:rolleyes:
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • kuntasensei
    edited July 2010
    That sucks, man. Shoot Oppo a message. They're pretty quick to respond.
    Equipment list:
    Emotiva XPA-3 amp
  • vmaxer
    vmaxer Posts: 5,120
    edited July 2010
    I can't believe it.. I sent an email and got a response today..The 4th of July!! That is great service. I still don't have it working, but couldn't ask for better response..
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited July 2010
    vmaxer wrote: »
    Someone is probably working answering emails from home on the deck.:)
