Oppo BDP 83 SE problems Bummer
vmaxer
Well, my Oppo BDP 83SE stopped outputting any video at all, nothing:mad: The only reset I see is in the menu....can't get that to work either. Since I have no video output, the only thing I can see is the front display on the Oppo. I can get it to show "setup menu" but nothing else.
Anyone have this happen to them?? Any ideas??
Long week-end and can't watch movies...I can listen to them:eek:
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
Post edited by vmaxer on
You could try reloading the firmware - maybe it got corrupted.
Do you have the latest from the Oppo website downloaded to a USB thumbdrive?
Erik Tracy wrote: »You could try reloading the firmware - maybe it got corrupted.
I usually do it via the network connection, but I wll download it and try it a bit later...Working in the yard at the moment.
Thanks for the suggestion!!Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Well, I backed up one version on the firmware...no change at all:mad:Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Have you tried swapping out your HDMI cable? It's a long shot I know but you never know..
It may sound silly but unplug it from the wall wait 30 secs and plug it back in.
REGARDS SNOWWell, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
TOOLFORLIFEFAN wrote: »Have you tried swapping out your HDMI cable? It's a long shot I know but you never know..
I am using component video cables, doubt all three would go out at once??It may sound silly but unplug it from the wall wait 30 secs and plug it back in.
REGARDS SNOW
Yep...tried that.
I can't seem to find a way to do a hard reset, but the firmware change did nothing either...I guess I will have to wait and send it back...
IPio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Press and hold the DISPLAY button for 10-15 seconds. When you release it, it should reset your video options to their defaults. That might get you going again. If it does, install the latest firmware, then do the reset to defaults in the menu, then clear persistent storage and plug in all your video options again.Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
kuntasensei wrote: »Press and hold the DISPLAY button for 10-15 seconds. When you release it, it should reset your video options to their defaults. That might get you going again. If it does, install the latest firmware, then do the reset to defaults in the menu, then clear persistent storage and plug in all your video options again.
Thanks, but no effect at all.....
Just not my day:rolleyes:Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
That sucks, man. Shoot Oppo a message. They're pretty quick to respond.Equipment list:
Emotiva XPA-3 amp
kuntasensei wrote: »That sucks, man. Shoot Oppo a message. They're pretty quick to respond.
I can't believe it.. I sent an email and got a response today..The 4th of July!! That is great service. I still don't have it working, but couldn't ask for better response..Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Someone is probably working answering emails from home on the deck.:)
