12 guage wire for these?
Mr. Sharpe
Just curious, but my dad has Polk RTA 12C's and Adcom Gfa 1-A and Gfp 1. the speakers are probably 4 feet from the amp and I gave him some 12 gauge wire I had sitting about 6 foot long each is this overkill or do you think "the bigger the better"?
My philosophy about hooking up speakers is use 12 gauge for all mains no matter how far away.
Home theater:
43” Westinghouse Displayer
Marantz UD-7007 Player
Emotiva MC-700 Processor
Adcom GFA-5006 Amplifier
Parasound Zamp Amplifier
Ethereal ESO-1 Power Conditioner
Klipsch RC-10 Center
Klipsch R34c Fronts
Klipsch RB-41 Surrounds
Polk audio PSW-505
Stereo:
Polk audio RTA-12c’s fully upgraded crossovers
DIY 12tc braided speaker cables
Denon DVD-5910ci Spinner
Parasound P6 Preamplifer
Parasound HCA -1500a Amplifier
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
Post edited by Mr. Sharpe on
"Philosophy" hopefully would be supported by the scientific realities of audio technology. At those very short distances 12ga could have no significant advantage over say, 18ga.
***grabs a bucket of chicken wings and a beer***
This is going to be fun.:D
You did well going with 12g wire for the runs. IMHO wires can have a significant impact on the way a speaker sounds. 18g wire is in no way something I would recommend to anyone. I don't think you need to go nuts on wires in your case, but this is one area I would not got for lamp cord either.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
John K. must be the life of the party wherever he goes."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Does your Dad like the sound his rig produces?If so,why does it matter what someone else thinks?Just a thought.If you can't hear a difference, don't waste your money.
Run the 12ga or 14ga.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Run a wire that sounds good.
actually 18 is too small, sorry.Home theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
Parasound HCA -1500a Amplifier -
who's that? what's that? who's he? that is the most confusing thing i've ever read LMAO. don't do that:pHome theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
good thought: not only does he value the opinion of others but he trusts his ear too, and he trusts me too and and he also knows that 12 gauge puts through the best audio signal and he's always used it.
gimme some chicken:DHome theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
I am so confused.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
concealer404 wrote: »I am so confused.
+1 to that.Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
Notta clue to what they're up to. Probably going on the "generic biwire v. audiophile cable" bits. As a starving student, I'm perfectly happy with my cheap #16 biwire and $1 Monster RCA cables.
#12 wire will be fine. With a short run like that, you can run even #22 without running into the impedance curve. Even so, if you already have the wires, just run what you've got. #12's just fine.polkaudio Monitor 5 Series II
polkaudio SDA-1 (with the SL1000)
TEAC AG-H300 MK III stereo receiver
beyerdynamic DT-880 Premium (600 Ω) headphones
SENNHEISER HD-555 headphones
Little Dot MK IV tube headphone amp
Little Dot DAC_I balanced D/A converter -
Home theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
No problem.
My personal view on the cable issue is based on priorities. I'd rather buy new or higher-quality source gear then spend the money on cables. Using #12-#16 on a small system with <8' runs is perfectly fine with me. The next $100 I get isn't going towards cables; it's probably going towards upgrading my headphone setup.
Tip: If you need inexpensive but good-quality cables in the USA, I've found Monoprice to the top choice.
http://www.monoprice.com/home/index.asppolkaudio Monitor 5 Series II
No problem.
Not having decent cabling and wires will compromise the sound that higher end gear is capable of producing. I am not saying that tens of thousands need to be spent on wires/cables, but a high quialty CD player will perform only as well as the rca's that carry the output signal. I subscribe to the 10/1 ratio. For every ten dollars I spend on a component, I will spend a buck on the cable. With the gear in my stack of stuff now, I will be more focused on tweeking things a bit and cables are at the top of my list.:)The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
No problem.
ya know, that sounds pretty good about the dollar on every $100 you spend, that's pretty much what he has, I gave him a monster 600 interconnect from amp to preamp, and another monster something for the CD, it's NAD too and it seriously made a difference!
I wanted to try Monoprice one time but decided not to for some reason, i just thought it was a little too good to be true:( I'll give it shot since I know you've tried em' and stuff:)Home theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
I should just stop quoting everybody on everything lol especially since I have to reply to everybody all the time:p
@nooshinjohn, I totally agree with you:) thanks.Home theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
nooshinjohn wrote: »With the gear in my stack of stuff now, I will be more focused on tweeking things a bit and cables are at the top of my list.:)
Tweaking the gear is what I have been doing for a while now. I have been really surprised at how much better the sound has become after adding brass footers for vibration, new speaker cables, and just recently new MIT XLR ICs.
Damn!!!!!! I just remembered. I have a $1200 MIT Magnum digital cable sitting in the car. I picked it up from UPS this morning, but got so involved at work I just came home and forgot all about it.
To the car!!!!! And upgrade my Wadia to DAC IC.
Review coming.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
HAHA! let me know BlueFox. I should really try some vibration things myself.Home theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
right on buddy:)Home theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
