12 guage wire for these?
Mr. Sharpe
Mr. Sharpe Posts: 1,359
Just curious, but my dad has Polk RTA 12C's and Adcom Gfa 1-A and Gfp 1. the speakers are probably 4 feet from the amp and I gave him some 12 gauge wire I had sitting about 6 foot long each is this overkill or do you think "the bigger the better"?
My philosophy about hooking up speakers is use 12 gauge for all mains no matter how far away.
Home theater:
43” Westinghouse Displayer
Marantz UD-7007 Player
Emotiva MC-700 Processor
Adcom GFA-5006 Amplifier
Parasound Zamp Amplifier
Ethereal ESO-1 Power Conditioner
Klipsch RC-10 Center
Klipsch R34c Fronts
Klipsch RB-41 Surrounds
Polk audio PSW-505
Stereo:
Polk audio RTA-12c’s fully upgraded crossovers
DIY 12tc braided speaker cables
Denon DVD-5910ci Spinner
Parasound P6 Preamplifer
Parasound HCA -1500a Amplifier
  • John K.
    John K. Posts: 822
    edited July 2010
    "Philosophy" hopefully would be supported by the scientific realities of audio technology. At those very short distances 12ga could have no significant advantage over say, 18ga.
    nooshinjohn Posts: 26,172
    edited July 2010
    John K. wrote: »
    ***grabs a bucket of chicken wings and a beer***
    This is going to be fun.:D
    You did well going with 12g wire for the runs. IMHO wires can have a significant impact on the way a speaker sounds. 18g wire is in no way something I would recommend to anyone. I don't think you need to go nuts on wires in your case, but this is one area I would not got for lamp cord either.
  • Face
    Face Posts: 14,340
    edited July 2010
    John K. must be the life of the party wherever he goes.
  • decal
    decal Posts: 3,205
    edited July 2010
    Does your Dad like the sound his rig produces?If so,why does it matter what someone else thinks?Just a thought.
  • ben62670
    ben62670 Posts: 15,969
    edited July 2010
    Run the 12ga or 14ga.
    Ben
  • concealer404
    concealer404 Posts: 7,440
    edited July 2010
    Run a wire that sounds good. :o
  • Mr. Sharpe
    edited July 2010
    John K. wrote: »
    actually 18 is too small, sorry.
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • Mr. Sharpe
    edited July 2010
    Face wrote: »
    who's that? what's that? who's he? that is the most confusing thing i've ever read LMAO. don't do that:p
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • Mr. Sharpe
    edited July 2010
    good thought: not only does he value the opinion of others but he trusts his ear too, and he trusts me too and and he also knows that 12 gauge puts through the best audio signal and he's always used it.
    gimme some chicken:D
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • concealer404
    edited July 2010
    I am so confused.
  • kawizx9r
    kawizx9r Posts: 5,150
    edited July 2010
    I am so confused.
    +1 to that.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • Bobsama
    Bobsama Posts: 526
    edited July 2010
    Notta clue to what they're up to. Probably going on the "generic biwire v. audiophile cable" bits. As a starving student, I'm perfectly happy with my cheap #16 biwire and $1 Monster RCA cables.
    #12 wire will be fine. With a short run like that, you can run even #22 without running into the impedance curve. Even so, if you already have the wires, just run what you've got. #12's just fine.
    polkaudio Monitor 5 Series II
    polkaudio SDA-1 (with the SL1000)
    TEAC AG-H300 MK III stereo receiver
    beyerdynamic DT-880 Premium (600 Ω) headphones
    SENNHEISER HD-555 headphones
    Little Dot MK IV tube headphone amp
    Little Dot DAC_I balanced D/A converter
  • Mr. Sharpe
    edited July 2010
    @concealer404: +1 to both of comments lol
    thanks bobsama!
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • Bobsama
    Bobsama Posts: 526
    edited July 2010
    No problem.
    My personal view on the cable issue is based on priorities. I'd rather buy new or higher-quality source gear then spend the money on cables. Using #12-#16 on a small system with <8' runs is perfectly fine with me. The next $100 I get isn't going towards cables; it's probably going towards upgrading my headphone setup.
    Tip: If you need inexpensive but good-quality cables in the USA, I've found Monoprice to the top choice.
    http://www.monoprice.com/home/index.asp
    edited July 2010
    Bobsama wrote: »
    No problem.
    Not having decent cabling and wires will compromise the sound that higher end gear is capable of producing. I am not saying that tens of thousands need to be spent on wires/cables, but a high quialty CD player will perform only as well as the rca's that carry the output signal. I subscribe to the 10/1 ratio. For every ten dollars I spend on a component, I will spend a buck on the cable. With the gear in my stack of stuff now, I will be more focused on tweeking things a bit and cables are at the top of my list.:)
  • Mr. Sharpe
    edited July 2010
    Bobsama wrote: »
    No problem.
    ya know, that sounds pretty good about the dollar on every $100 you spend, that's pretty much what he has, I gave him a monster 600 interconnect from amp to preamp, and another monster something for the CD, it's NAD too and it seriously made a difference!
    I wanted to try Monoprice one time but decided not to for some reason, i just thought it was a little too good to be true:( I'll give it shot since I know you've tried em' and stuff:)
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • Mr. Sharpe
    edited July 2010
    I should just stop quoting everybody on everything lol especially since I have to reply to everybody all the time:p
    @nooshinjohn, I totally agree with you:) thanks.
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • BlueFox
    BlueFox Posts: 15,250
    edited July 2010
    Tweaking the gear is what I have been doing for a while now. I have been really surprised at how much better the sound has become after adding brass footers for vibration, new speaker cables, and just recently new MIT XLR ICs.
    Damn!!!!!! I just remembered. I have a $1200 MIT Magnum digital cable sitting in the car. I picked it up from UPS this morning, but got so involved at work I just came home and forgot all about it.
    To the car!!!!! And upgrade my Wadia to DAC IC.
    Review coming.
  • Mr. Sharpe
    edited July 2010
    HAHA! let me know BlueFox. I should really try some vibration things myself.
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • Mr. Sharpe
    edited July 2010
    right on buddy:)
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
