SVS PB10-NSD best sub for money ?
Dan2036
Dan2036 Posts: 148
Looking to upgrade my psw10, I'm considering the SVS PB10 but I just want to make sure its the best sub for the price and for what i wanna use it for. 60% Music 40% Movies.
TV- Samsung 24" LCD T240HD
5.1 Receiver - Harman/Kardon AVR 247
Stereo Receiver - Harman/Kardon 3390
Front - Monitor 60
Center - Cs10
Surround - Tsi100
Sub - SVS PB10-NSD :D
Playstation 3
Post edited by Dan2036 on
  • Dan2036
    Dan2036 Posts: 148
    edited June 2010
    Also considering Hsu VTF-1 and Mirage Omni S10
    Front - Monitor 60
    Center - Cs10
    Surround - Tsi100
    Playstation 3
  • kawizx9r
    kawizx9r Posts: 5,150
    edited June 2010
    I hear Mirage's subs are very musical, just throwing that out there.
    What's your budget?
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • Dan2036
    Dan2036 Posts: 148
    edited June 2010
    Ya i've heard the same, Budgets around 500$ less is always good (:
    Front - Monitor 60
    Center - Cs10
    Surround - Tsi100
    Playstation 3
  • gfong
    gfong Posts: 1,079
    edited June 2010
    I just purchased the SVS PB12 and it works great for music and great for movies, I have listened to SACD, CD's and vinyl and it handles them great.
    When I went to purchase the SVS sub the only reason I went with the 12 over the 10 was the size of room I have to fill. If my room was smaller I could have went with the PB10!
    SVS build is quality and the sound is outstanding! If you do decide to go with SVS you will not be disappointed. Good luck with your choices!
  • danz1906
    danz1906 Posts: 5,144
    edited June 2010
    Yes!!!!!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • Dan2036
    Dan2036 Posts: 148
    edited June 2010
    Haha good cause I just ordered it
    Front - Monitor 60
    Center - Cs10
    Surround - Tsi100
    Playstation 3
  • dorokusai
    dorokusai Posts: 25,576
    edited June 2010
    It's a pretty decent subwoofer and a great value.
  • Dan2036
    Dan2036 Posts: 148
    edited June 2010
    It'll probably overpower my small 11x10 room
    Front - Monitor 60
    Center - Cs10
    Surround - Tsi100
    Playstation 3
  • kuntasensei
    kuntasensei Posts: 3,263
    edited June 2010
    There's no such thing as "overpower" when it comes to quality bass. ;)
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • gfong
    gfong Posts: 1,079
    edited June 2010
    Dan2036 wrote: »
    I can not wait for your review once you have had a chance to hear it! :) It will knock your socks off! :)
    edited June 2010
    The Sensei is very 'wise' and also RIGHT!
    Enjoy your new sub!
    cnh
  • Dan2036
    Dan2036 Posts: 148
    edited June 2010
    So this thing is huge, biggest 10" sub i've ever seen. Very high build quality you can just tell from looking at it. I haven't had much time to listen to the sub but from what i've heard i've noticed a few things. First it blends in a thousand time better with my Monitor 60's, the psw10 used to stick out like a sore thumb with overwhelming bass. The pb10 just seamlessly fills out the bottom end of music. As far as movies i've already just grazed the bassiest scenes of LOTR The Two Towers and Jurassic Park. Very cool, you can literally feel what you see. Only question mark for me is how loud can I actually push this thing, my room is 11x10 and I like how loud it is but feel like I need more, pretty sure the sub can do more. Is there any way to check if i'm pushing it to much ??
    Front - Monitor 60
    Center - Cs10
    Surround - Tsi100
    Playstation 3
  • gfong
    gfong Posts: 1,079
    edited June 2010
    Dan2036 wrote: »
    Where do you have the volume control at and where do you have it crossed over at?
  • Dan2036
    Dan2036 Posts: 148
    edited June 2010
    Gain is at about 4/10 and I have the subs crossover off, on the receiver the crossover for the main speakers and the sub is 80hz. 100hz for the center and surrounds. Could placement be the problem, I just switched it to right beside my seat to see if i would get more that way.
    Front - Monitor 60
    Center - Cs10
    Surround - Tsi100
    Playstation 3
  • gfong
    gfong Posts: 1,079
    edited July 2010
    Dan2036 wrote: »
    Are you lacking the hard hitting low bass or is it just not loud enough for you at any volume? Is it the music or the movies that the volume is not loud enough? Is it both?
    Are you using any calibration tools or calibration tools that came with the AVR?
    Try putting it in the front stage facing you, that may not be the final location, but it is a good start. I have found and it is not always the case but if the sub is infront of the mains or at the rear seating area the sub will most likely be out of phase.
    http://www.polkaudio.com/forums/showthread.php?t=73201&highlight=crawling+bass
    (post 7 details a nice way on how to find the best placement.)
    For settings I would put the gain at 12 oclock and turn the crossover on the sub all the way to the right (120) and also disable the crossover.
    Hope that helpos, lets us know if anything changes! Goodluck.
  • kuntasensei
    edited July 2010
    I was gonna ask if you redid the EZSet on your H/K after you put the SVS in the chain. Not sure how extensive H/K's equalization of the sub is, but it's something to consider.
    As far as the gain goes, usually 1/3 on an SVS sub is about right. The key is to adjust gain on the sub so that your AVR's level trim ends up between 0 and about -4 to ensure that you aren't overloading the line-in when you crank the volume up.
    Equipment list:
    Emotiva XPA-3 amp
  • Dan2036
    Dan2036 Posts: 148
    edited July 2010
    Mostly lacking the hard hitting deep bass but volume too. Thing is I can see the driver moving like crazy, I just don't seem to hear sound equivalent to the movement. I did use the EZSet, all it did was lower the volume on my center channel, which I didn't like at all. I will try the crawling method when I get a chance. I had my subwoofer on my avr at +5 and the gain a tad higher then 1/3 so i'll have to lower the AVR's level.
    Front - Monitor 60
    Center - Cs10
    Surround - Tsi100
    Playstation 3
  • gfong
    gfong Posts: 1,079
    edited July 2010
    Dan2036 wrote: »
    Here is some info right from the SVS site!
    It’s a good idea to check the subwoofer level control of your receiver before you begin the test tones. Keep the receiver's subwoofer output control to about 25% up or lower than "0 dB" (or say -6dB given a typical receiver channel limits of –12 dB to +12 dB) . This will allow your amp to work with the cleanest signal possible from your receiver, while still leaving plenty of downward adjustment you can use from your viewing position (using the remote).
  • kuntasensei
    edited July 2010
    By the way, make sure you have PHASE set to 0 on the SVS before doing EZSet. That way, the distance it detects at the mic should be the correct distance for keeping the sub in phase with the other channels.
    Equipment list:
    Emotiva XPA-3 amp
  • Ron Temple
    Ron Temple Posts: 3,212
    edited July 2010
    1st...deep low bass isn't impactful, it's visceral. The lowest octave 30 -15hz is a mixture of very low effects and infrasonics. The impact and punch comes from 50 -100hz. Subs like the SVS are designed to be flat from just below tuning to around 100hz. Many first timers are underwhelmed at first because they are used to the midbass hump from conventional retail subs. That's usually a matter of taste and most get addicted to the cleaner flat bass very quickly.
    2nd...you've got a nearly square, small room. Square rooms usually suffer from cancellation and the bass waves bounce and fold back on themselves. You're going to have to try various placement options and probably learn REW to see where your problems lie. I'm guessing you'll find a chasm in the 40-60hz range. Furniture re-arrangement might be mandatory.
    Jack Gilvey from SVS or Ed Mullen can be very helpful if you contact them with your room layout. Give them a try.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • kuntasensei
    edited July 2010
    Ron Temple wrote: »
    +1. Ed Mullen has always been super helpful, even before he joined SVS. Their customer support is outstanding.
    Equipment list:
    Emotiva XPA-3 amp
  • Dan2036
    Dan2036 Posts: 148
    edited July 2010
    Would I need to send Ed or Jack a picture or diagram of the setup ?
    Front - Monitor 60
    Center - Cs10
    Surround - Tsi100
    Playstation 3
  • Dan2036
    Dan2036 Posts: 148
    edited July 2010
    Also, should I have my front speakers set to "small" or "large" on the receiver ??
    Front - Monitor 60
    Center - Cs10
    Surround - Tsi100
    Playstation 3
  • Dan2036
    Dan2036 Posts: 148
    edited July 2010
    Ok problem fixed, I had to move the sub in between the tv stand and the right front speaker. Now it faces the couch and it angled in a bit. I have all the other speakers set to small. I think I was getting standing waves or something. Now the sub truly does blow me away, music sounds awesome, and movies just shake all the walls. The best part is with the deep floor shaking bass it feels controlled, It's not just one note either, every rumble or shake is different feeling.
    Appreciate all the help guys, very informative.
    -Dan
    Front - Monitor 60
    Center - Cs10
    Surround - Tsi100
    Playstation 3
  • denissharper
    denissharper Posts: 1
    edited July 2010
    I never had the chance to hear one of them. I was ready to SVS order based on ratings, aesthetics (sp?) And even the dimensions. both fit perfectly and the price I want. Well, Klipsch is $ 700, but I have a chance to get it for $ 475. SVS plus postage will be $ 480.
  • fx20
    fx20 Posts: 26
    edited August 2010
    How does this SVS' compared to Hsu STF-2 in music listening? I am considering also Polk's DSW micro2000, any comment?
  • Ron Temple
    edited August 2010
    fx20 wrote: »
    The Hsu is a nice sub and I don't believe it would give anything away to the SVS in musical performance. The SVS will go deeper. Haven't heard the MP2K, but I wouldn't trade the Hsu for one. I'd think it would be a wash muscially with the Hsu with less output.
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
