Best tweeks for the SDA's
  • hearingimpared
    hearingimpared Posts: 21,136
    edited July 2010
    thsmith wrote: »
    Hearing, jb weld is an epoxy that you mix. Use a pop sickle stick to mix and apply to magnet and mounting plate.
    Thanks you sir. How important is this "tweak" as I may do it when I install the rings.
  • headrott
    headrott Posts: 5,496
    edited July 2010
    Joe, DO IT! It is highly important, especially the older the drivers get. The glue on the magnets will only last so long until it gives out and your driver magnet shifts resulting in a frozen driver. PLus, it's easy and cheap. Good combo.
    Greg
  • hearingimpared
    edited July 2010
    headrott wrote: »
    Greg
    I shall comply oh wise one!:D Seriously, it makes all the sense in the world.
  • helipilotdoug
    helipilotdoug Posts: 1,230
    edited July 2010
    Here are some links that I have found very helpful and great reading. I'm sure there are more, so if you know of any more, please post them.
    Most of the tweaks are covered in this great post started by TOOLFORLIFEFAN:
    http://www.polkaudio.com/forums/showthread.php?t=97719
    And another thread by nspindel that covers several tweaks:
    http://www.polkaudio.com/forums/showthread.php?t=62106
    Mortite:
    http://www.polkaudio.com/forums/showthread.php?t=74524
    Dynamat:
    http://www.polkaudio.com/forums/showthread.php?t=52810
    Hardware Rings:
    http://www.polkaudio.com/forums/showthread.php?t=103241
    SDA2B Crossover upgrade:
    http://www.polkaudio.com/forums/showthread.php?t=87121
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
  • headrott
    edited July 2010
    Yeah Joe, it does make sense. It will also result in spending less dollars in the future, as well as minus the frustration of having to find and replace the drivers. Also good things. Also seriously, the wise ones are the people who came up the ideas of the mods and tweaks. Larry being a good example of that.:cool:
    Greg
  • hearingimpared
    edited July 2010
    Thank you Sir!
    pitdogg2 Posts: 27,769
    edited July 2010
    You may try one like the spike on the right:
    Madisound also has great feet search for tiptoes on their site.
    Very well made also very affordable:D
  • hearingimpared
    edited July 2010
    Are these the "tiptoes" that came out in the '80s? If so I had dozens of them in different sizes and at the time the were wonderful. If they haven't changed the material they are made of (aluminum) or modified their design there are much much better products of this sort availiable in 2010 made of carbon fiber, brass, and composites and designed differently.
    Not raining on your parade Bro just sharing my experience as I used them for years. As a matter of fact I passed all the extras I had to Polkies over the years.
    Do you know if they are any different now?:) I tried searching their site but I could only find floor protectors.
  • vmaxer
    vmaxer Posts: 5,121
    edited July 2010
    These say they are plated brass???
    https://www.madisound.com/store/product_info.php?products_id=1050
    I have ordered and received these for my C's, but haven't installed them yet...
    https://www.madisound.com/store/product_info.php?products_id=1047
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • hearingimpared
    edited July 2010
    vmaxer wrote: »
    Thanks Billy they are quite different in design and material than the original "tiptoes." Jeez I really have become search impaired as I was all over that site with every keyword I could think of and couldn't find them and you do in a matter of minutes.
    Time for this old man to take a nap and reboot his memory cells.:rolleyes:
  • vmaxer
    vmaxer Posts: 5,121
    edited July 2010
    Well, they turn up when you search feet....who woulda thought??? It was just because I recently ordered them that I remembered.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • hearingimpared
    edited July 2010
    vmaxer wrote: »
    FEET!?! What do they specialize in podiatric supplies?:D
  • vmaxer
    vmaxer Posts: 5,121
    edited July 2010
    The downside is that we would have to buy shoes for the "feet" for our speakers...:p
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
