Bookshelf vs Towers on rears/surrounds
scoobygt68
scoobygt68 Posts: 19
edited June 2010 in Speakers
I currently run Paradigm 100 v2s on my rears and my surrounds. Im considering moving to 4 Paradigm Signature ADP3s on my 4 back channels. Will I notice a loss a loss of the towers in the rear?
Fronts: Paradigm Signature S8 v3
Center: Paradigm Signature C5 v3
Rears: Paradigm Studio 100 v2
Surrounds: Paradigm Studio 100 v2
Sub: Def Tech Trinity
Display: Epson 8500 UB on 120" screen
Processor: Yamaha rx-v3800
Amp: Emotiva XPA-5
Xbox 360
PS3
Post edited by scoobygt68 on
  • cstmar01
    cstmar01 Posts: 4,424
    edited June 2010
    scoobygt68 wrote: »
    huh?
    are you trying to say will you notice a difference?
    if so normally using bookshelfs is a little different than towers, as you can move the tweeter up higher on the wall or have better placement options. Towers normally don't get used to their full potential when being used as a surround as there isn't often much information given to those channels that would require as large of a speaker. Also if you have a sub and cross it over at say 80 the sides surrounds are not going to see really anything that a tower would have to handle.
    Also if using a di/bipole speaker I prefer this over a tower. The sound is less localized and sounds more as a "surround speaker" I've found rather than just another speaker where I can pin point the location easily.
  • Midnite Mick
    Midnite Mick Posts: 1,591
    edited June 2010
    I have done both. I would never use towers again...totally unnecessary in my opinion.
    It is also difficult to get towers to the height that is ideal.
    Regards,
    Mike
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
