fxi30 help!
gwh
gwh Posts: 1,451
edited December 2003 in Speakers
Placing speakers on back wall , if I put the left on the left side of the room that puts the 5.25 facing the left side wall, same on the right side. Is this correct? or should the 5.25's be facing inward?
Thanks,
G
HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects.
Post edited by gwh on
  • dorokusai
    dorokusai Posts: 25,623
    You have mounted them correctly.
  • gwh
    gwh Posts: 1,451
    Rock on brother!
    Thanks for the help!
    G
    HT:
    Emotiva Airmotiv E2
    SVS SB16 Ultra
    Yamaha RX-A3070
  • pcgorilla
    pcgorilla Posts: 39
    I will be getting a pair of Fxi 5's. I have a similar question. They will be on the back wall.
    Now, on my LEFT side (left when watching tv) the speaker is about 1 foot away from the wall.
    On my RIGHT side (right when watching tv) they are on the wall, which opens into the kitchen, so there is no wall.
    Which side should the Woofer be positioned....Out, towards the wall (and kitchen)or in, towards the middle.
    Also, Bi Pole or Di-Pole? Speakers are about 4 feet above listening position and about 1 foot behind couch.
    thanks
  • dorokusai
    PC - I would mount them as described in the manual....like above post by GWH. As far as Bipole/Dipole...that IMO is just a suggestion, not a rule. I would use what sounds best for your room.
    I would bet that Bipole will in fact be your best choice, beings you have that opening nearby.
    The Bipole mode will radiate a much larger soundstage than Dipole will. Bipole is the recommended setting for rear wall applications.
