Tweeters
Hello,
is it possible to put the CSI5 tweeter on a RTi12 speaker?
i know the mount is not fit but is this an Identical tweeter?
Thanks,
Thanks,
Post edited by Rino on
yep, identical, same with the rest of Rti series and csi3. but wouldn't it be cheaper and less work to make it fit if you just get a RTi12 tweeter only?
Sure
One of my Rti12s has a damage tweeter and I need to get a replacement from the reseller so just for a temporary solution .
BTW can I buy a tweeter directly from Polk? -
Yep, just call their customer service.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
The tweeters ate not identical,
I just got a replacement tweeter to my Rti12 and the sound was different,
Looking into the white sticker on the back of the tweeter shows DPD24 for the original one and DPE15 on the replacement,
I guess both are different parts numbers, with different performances,
Does anyone familiar with this?
Thanks,
