Tweeters
Rino
Rino Posts: 14
edited June 2010 in Speakers
Hello,
is it possible to put the CSI5 tweeter on a RTi12 speaker?
i know the mount is not fit but is this an Identical tweeter?
Thanks,
Post edited by Rino on
  • nhhiep
    nhhiep Posts: 877
    edited June 2010
    yep, identical, same with the rest of Rti series and csi3. but wouldn't it be cheaper and less work to make it fit if you just get a RTi12 tweeter only?
  • Rino
    Rino Posts: 14
    edited June 2010
    Sure :)
    One of my Rti12’s has a damage tweeter and I need to get a replacement from the reseller so just for a temporary solution….
    BTW – can I buy a tweeter directly from Polk?
  • quadzilla
    quadzilla Posts: 1,543
    edited June 2010
    Yep, just call their customer service.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • Rino
    Rino Posts: 14
    edited June 2010
    The tweeters ate not identical,
    I just got a replacement tweeter to my Rti12 and the sound was different,
    Looking into the white sticker on the back of the tweeter shows DPD24 for the original one and DPE15 on the replacement,
    I guess both are different parts numbers, with different performances,
    Does anyone familiar with this?
    Thanks,
