Rti150 on sale single only... is it worth it?
doggie750
doggie750 Posts: 1,169
edited December 2003 in Speakers
For $130, is it worth getting it just to play SACD/ CD on it? Multi room purpose only? Or may be use it as my 6th channel. What u think? Thank you folks polks.
Doggie
:rolleyes:
Godspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon
Post edited by doggie750 on
  • brettw22
    brettw22 Posts: 7,623
    Might be a mean rear center channel.......but using a tower as a center channel is a personal thing. For me, it would be an aesthetic eyesore to have a single tower sitting back there. I like things balanced (in both sound, and looks) when it comes to the layout of my system, so I personally wouldn't like it (that also completely depends on what your other speakers are, and if the 150 would blend properly with them without being over-bearing)
  • TheMaster
    TheMaster Posts: 184
    I could not agree more with what Brett had to say. I would save up the dough and buy my self a good amp for the fronts. If you want to hear a quick improvement, get a decent speaker wires for your fronts ( I would buy them Signal Cables).
    Slow your phase down a bit when buying something for your HT. Do a research on what is best fit for your setup now and work your way up from there. Why don't you post your rig here in the forum and let the experts help you figure out how to set them up or which one to upgrade or what to add.
    Good Luck,
    glenn
    HT:
    DENON AVR-3803
    DENON DVM-1805
    SONY DVP-NS300
    SONY 36' HDTV Wega
    ADCOM GFA-555
    ADCOM GFA-555
    ADCOM GFA-2535
    ADCOM ACE-515
    POLK RTi70's (Bi-Amped)
    POLK CSi40
    POLK FXi30's
    POLK RTi38's
    POLK CSi20
    POLK PSW 450
    SVS PB2 Plus
    2 CH Stereo:
    AudioSource Pre/Amp 1
    Hafler DH-500
    Sony CDP-CX235
    Monster Cable HTS3500
    SDA SRS 2.3tl
  • doggie750
    thanks brett,
    For SACD/ CD only purposes, this giant would be invisible as soon as you enter the room. 2 sofas joint together leave you a corner, thus lead you a possible location for the rti150 behind a vase & and a plant. Please advise.
    Godspeed,
    D0661E
    Surrounds: RTis
    Sub:SVS PB12-Plus/2
  • brettw22
    You have to tell us what your other speakers are. What amps/receiver are you driving everything with, etc.
    To just blindly say that a 150 would be the right move would be careless if it wouldn't match at all what you have.....
    Give us the details.......
    VR3 Posts: 29,697
    Receiver: Sony STRDB 1070 6.1 600w
    Front: Rti100
    Center: Csi40
    Surround: Fxi30
    Rearside:maybe Rti70 (what u
    all think????)
    Sub: still shopping
    AMP: still shopping
    Widescreen: still shopping
    Budget: low
    GIXXER rules
    Its in his sig.....
