Rti150 on sale single only... is it worth it?
For $130, is it worth getting it just to play SACD/ CD on it? Multi room purpose only? Or may be use it as my 6th channel. What u think? Thank you folks polks.
Doggie
:rolleyes:
Doggie
:rolleyes:
Godspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
Post edited by doggie750 on
Might be a mean rear center channel.......but using a tower as a center channel is a personal thing. For me, it would be an aesthetic eyesore to have a single tower sitting back there. I like things balanced (in both sound, and looks) when it comes to the layout of my system, so I personally wouldn't like it (that also completely depends on what your other speakers are, and if the 150 would blend properly with them without being over-bearing)comment comment comment comment. bitchy.
I could not agree more with what Brett had to say. I would save up the dough and buy my self a good amp for the fronts. If you want to hear a quick improvement, get a decent speaker wires for your fronts ( I would buy them Signal Cables).
Slow your phase down a bit when buying something for your HT. Do a research on what is best fit for your setup now and work your way up from there. Why don't you post your rig here in the forum and let the experts help you figure out how to set them up or which one to upgrade or what to add.
Good Luck,
glennHT:
DENON AVR-3803
DENON DVM-1805
SONY DVP-NS300
SONY 36' HDTV Wega
ADCOM GFA-555
ADCOM GFA-555
ADCOM GFA-2535
ADCOM ACE-515
POLK RTi70's (Bi-Amped)
POLK CSi40
POLK FXi30's
POLK RTi38's
POLK CSi20
POLK PSW 450
SVS PB2 Plus
2 CH Stereo:
AudioSource Pre/Amp 1
Hafler DH-500
Sony CDP-CX235
Monster Cable HTS3500
SDA SRS 2.3tl -
thanks brett,
For SACD/ CD only purposes, this giant would be invisible as soon as you enter the room. 2 sofas joint together leave you a corner, thus lead you a possible location for the rti150 behind a vase & and a plant. Please advise.Godspeed,
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
Odyclub; Xsimulator; Sony; Zune; Canon -
You have to tell us what your other speakers are. What amps/receiver are you driving everything with, etc.
To just blindly say that a 150 would be the right move would be careless if it wouldn't match at all what you have.....
Give us the details.......comment comment comment comment. bitchy. -
Receiver: Sony STRDB 1070 6.1 600w
Front: Rti100
Center: Csi40
Surround: Fxi30
Rearside:maybe Rti70 (what u
all think????)
Sub: still shopping
AMP: still shopping
Widescreen: still shopping
Budget: low
GIXXER rules
Its in his sig.....- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
