Help understanding sub frequency response info
Ern Dog
Ern Dog Posts: 2,237
So, I was looking up the frequency response for a JL Audio Fathom F110 sub in their website (here) and found this data but I'm not sure how to interpret it:
27 - 111 Hz (1.5dB)
-3 dB at 25 Hz / 120 Hz
-10 dB at 19 Hz / 155 Hz
Any help would be appreciated. thanks
Post edited by Ern Dog on
  • thsmith
    thsmith Posts: 6,082
    edited June 2010
    Here is the way I see the data.
    27 - 111 Hz (1.5dB)
    Flat within 1.5db from 27hz to 111hz
    Flat within 3db from 25hz to 120hz
    flat within 10db 19hz to 155hz
  • Ron Temple
    Ron Temple Posts: 3,212
    edited June 2010
    I wouldn't be concerned about the higher number. To expand on what Tracy said...
    The sub is fairly flat at 27hz, probably starts rolling off around 28-29hz. It's down 3db at 25hz (from 27) and it's down 10db at 19hz (again from 27). That's very good extention for a sealed 10" sub and if you get room/boundary gain, you should be flat into the low 20s, perhaps further.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • Ern Dog
    edited June 2010
    Cool beans. Thanks for the info Tracy and Ron.
    Now I need to start saving some cash units.
  • ShinAce
    ShinAce Posts: 1,194
    edited June 2010
    thsmith wrote: »
    27 - 111 Hz (1.5dB)
    -3db @ 25hz and 120hz
    -10db @ 19hz and 155hz
    Fixed! Although the way you wrote it isn't exactly wrong. It should very well be +/-10 dB from 19-155 Hz.
    Sub response is useless unless they state anechoic or in-room. Besides, the room plays such a big part.
    Ron: The room will need to be very small to get cabin gain below 20 Hz.
