Help understanding sub frequency response info
Ern Dog
So, I was looking up the frequency response for a JL Audio Fathom F110 sub in their website (here) and found this data but I'm not sure how to interpret it:
27 - 111 Hz (1.5dB)
-3 dB at 25 Hz / 120 Hz
-10 dB at 19 Hz / 155 Hz
Any help would be appreciated. thanks
27 - 111 Hz (1.5dB)
Post edited by Ern Dog on
Here is the way I see the data.
27 - 111 Hz (1.5dB)
Flat within 1.5db from 27hz to 111hz
Flat within 3db from 25hz to 120hz
flat within 10db 19hz to 155hzSpeakers: SDA-1C (most all the goodies)
I wouldn't be concerned about the higher number. To expand on what Tracy said...
The sub is fairly flat at 27hz, probably starts rolling off around 28-29hz. It's down 3db at 25hz (from 27) and it's down 10db at 19hz (again from 27). That's very good extention for a sealed 10" sub and if you get room/boundary gain, you should be flat into the low 20s, perhaps further.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Cool beans. Thanks for the info Tracy and Ron.
Now I need to start saving some cash units. -
27 - 111 Hz (1.5dB)
-3db @ 25hz and 120hz
-10db @ 19hz and 155hz
Fixed! Although the way you wrote it isn't exactly wrong. It should very well be +/-10 dB from 19-155 Hz.
Sub response is useless unless they state anechoic or in-room. Besides, the room plays such a big part.
Ron: The room will need to be very small to get cabin gain below 20 Hz.
