SVS sub on ebay
Strong Bad
Strong Bad Posts: 4,278
edited December 2003 in Flea Market
No excuses!
Post edited by Strong Bad on
  • dorokusai
    dorokusai Posts: 25,631
    edited November 2003
    What is up with that second picture, closeup of the tube fabric? I would certainly hope that it is not standard workmanship.
  • scottvamp
    scottvamp Posts: 3,277
    This is without the amp???????
  • Dr. Spec
    Dr. Spec Posts: 3,780
    Doro/Scott:
    The fabric can be wrinkled and "hiked-up", if the sub is lifted up and down a bunch of times.
    It can be easily fixed with a "smoothing of the skirt" type motion. Too bad he snapped the pic that way - his loss I guess.
    The fabric is actually very nice in person - it reminds me of a mix between velvet and corduroy.
    This is a passive subwoofer and needs an external amp. HBomb owns two with a Samson S1000 and loves them.
    It has the TC Sounds dB-12 "Plus" driver, and triple 3" flared ports with variable tuning. The seller should include two port plugs. The stock tune is 20 Hz, and 16 and 12 are available with the port plugs.
    Anyone with a spare amp who needs a sub (Tour2ma) should watch this one closely - this is a REALLY great performing unit. It is the passive version of the 20-39 PC-Plus I owned for over a year.
    SVS
  • RuSsMaN
    RuSsMaN Posts: 17,985
    Well, I WAS watching it. Too bad the dipshit parade is in full swing, running up the bid with FIVE days left.
    It's mine! No, it's mine! Mine!
    Idiots.
  • Dr. Spec
    I know - I like to sit tight and bid in the last 15 seconds of the auction.
    Maybe there's still hope. You can save on shipping, certainly. And he said it was advertised locally as well. He reserves the right to sell it locally, so give him a call and see what he says.
    A 500 watt amp would be perfect, but anything over 300-350 will work well. I imagine he has an amp too (possibly the S1000). I wonder if he is advertising that as well in another eBay post?
    SVS
  • Strong Bad
    If you click on "View sellers other items" or the link below, he is selling a Carver TFM 22 amp. He states it as 500w x 2 or 1000w bridged mono.
    I assume this is what he was running the sub with. He could have taken better pics. Fix the damn fabric for crying out loud!
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=39783&item=3062276504
    John
    No excuses!
  • burdette
    burdette Posts: 1,194
    Just curious... what does SVS use to make that bottom plate?
  • HBombToo
    HBombToo Posts: 5,256
    Originally posted by Dr. Spec
    Doro/Scott:
    YES SIR!!!
    Best buy I made for HT IMHO then comes the Denon 2900. I'm a Doc Spec copy cat:D 800i's and all!
    1/4 Twin
    ***WAREMTAE***
  • HBombToo
    There is no bottom plate per say... The woofer just screws into the can. I had to replace mine and did not see or touch a plate?
    1/4Twin
    ***WAREMTAE***
  • Dr. Spec
    The base plate is made from hardwood and painted black. The support dowels are hardwood too.
    SVS
  • HBombToo
    if thats what the base plate is I stand corrected. just not my notion of a plate(the question) which shows my ignorance.
    sorry for any confusion
    Twin
    ***WAREMTAE***
  • danger boy
    danger boy Posts: 15,722
    where in the auction does it say it doesn't come with an amp? I must have missed that part of it. Or do all 20-39PCi plus not come with amps?
    PolkFest 2012, who's going>?
  • danger boy
    those sure don't come up on ebay ever... this is the first SVS i've seen on there. once in a while an HSU will pop up too.
    smoooooth out the black fabric.. i did on mine.. even though it's dark in the room and it can't be seen.. i just would be beside myself if I knew the fabric was wrinkled. :p
  • Strong Bad
    The model is a 20-39 CS Plus. It requires an outboard amp.
    No excuses!
  • Loud & Clear
    Loud & Clear Posts: 1,538
    15 seconds!? If I tap out with more than 5 seconds remaining in an auction I can't ****, let alone win the auction. ;>}
    Danger - All SVS 'CS' subs are passive. No plate amps to be found.
    Two Channel Setup:
    Speakers: Wharfedale Opus 2-3
    Integrated Amp: Krell S-300i
    DAC: Arcam irDac
    Source: iMac
    Remote Control: iPad Mini
    3.2 Home Theater Setup:
    Fronts: Klipsch RP-160M
    Center: Klipsch RP-160M
    Subwoofer: SVS PB12NSD (X 2)
    AVR: Yamaha Aventage RX-A2030
    Blu Ray: Sony BDP-S790
    TV Source: DirecTV Genie
