How to fix Engine Ping/Knock
PerfectCreature
PerfectCreature Posts: 1,456
edited June 2010 in The Clubhouse
Thought I was In club house, mods please move to club house. Thanks.
So, I have spent hours looking online and a couple days talking to mechanics, and they keep leaving me confused.
So, how do I fix this annoying problem.
Here's the back ground. I start my car my engine pings, when I rev it up it pings. It may go away at a certain rev count, but will come back a little quieter after the engine is warmers and has been used awhile.
I use regular unleaded, my spark plugs and wires were changed (unsure of the brand) last year, I just changed my air filter with fram extra guard.
My oil is Penzoil High milage, and my oil filter is Fram Extra guard High milage(I need to change my oil in another 1000 miles are so, but wouldn't mind changing it again if it turns out to be the filter which is what I have read online).
I am wondering if it is the fram filter due to some of the research I have done, but am also curious is all of a sudden my car needs higher octane gas. Which would be odd.
Um, lets see it's been doing this for awhile now, and never really bothered me until I read somewhere that it could be serious.
Since I am planning on eventually selling this to a co-worker (Talked about in another thread) when I find a car that I like, I don't want to leave him with a major problem, so I would like it fixed.Plus, if I decide to keep it...I don't want a major problem either.
It has a 3.1 engine... v6...Um. I can't think of anything else that you would need in order to help. Right now it is a moderate climate, and it has done it through winter, but it was so much worse in the winter, like it was really loud in the winter time. Uh... I travel 50 miles a day.... no dirt roads, not sure if this would matter.
ANyway.
So, who has ideas on how to fix this, or what it may be?
Thanks so much :)
Receiver
Harman Kardon HK 3490
Speakers
Polk Audio Monitor 50s
Subwoofer
Klipsch KSW-100
Cables
AudioQuest Rocket 33s 10ft
AudioQuest Optilink1 2m
AudioQuest Alpha-Snake 25ft Interconnect
AudioQuest HDMI-1 2m
Alienware X51 R2
PS4
Samsung Smart TV 40" 1080p 3D
Post edited by PerfectCreature on
«13
    nooshinjohn Posts: 25,917
    edited June 2010
    ANyway.
    Thanks so much :)
    If it is a GM 3.1, time to junk it and get a new car. These motors along with their 3.4L cousins rank among the worst engines in GM history.
  • Ricardo
    Ricardo Posts: 10,636
    edited June 2010
    Try modifying the crossover, changing cables, maybe adding an external amp might also help.
    SOPA
    tonyb Posts: 33,072
    edited June 2010
    Best advice anyone can give you is to dump that car while it's still running. Once it stops running,it won't be worth much will it? Preferably not to a friend either if you value that friendship. Thats the bottom line to your car woes.
  • shack
    shack Posts: 11,154
    edited June 2010
    Check your timing, but the pinging/knock is probably caused by carbon deposits on the valves or weak valve springs...either of which could cause the problem. Using a higher octane fuel is the easy fix to stop the knock...but it doesn't fix the problem. However it will probably stop any damage from occuring.
  • concealer404
    concealer404 Posts: 7,440
    edited June 2010
    It's a 3.1. It'll run like crap for at least another couple years.
  • Fongolio
    Fongolio Posts: 3,516
    edited June 2010
    It sounds like a sensor is malfunctioning. GM 3.1's had dozens of sensors including electronic spark control, throttle position sensor, oxygen sensor, speed sensor, coolant temperature sensor etc etc. The two that malfunction most often are oxygen sensor and coolant temperature sensor. If either of these is giving an inaccurate reading to the computer your spark timing could be off which causes ping. Is your service engine soon light coming on? If you plan to keep this car for anytime you need to find which sensor is messed up and replace it. Otherwise the above advice applies. Some manuals tell how to tap the computer and read the flashing lights and interpret the codes just with a jumper wire (works on my '89 IROC). Good luck.
    Kelvin
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • PerfectCreature
    edited June 2010
    No engine lights have come on at all. So, I probably will want to sell it then, and beef it up with a full tank of premium before the sale ha!
    No, Um, I am getting my transmission oil changed along with the filter replaced, I will ask the mechanic to check on it at the time of the change.
    I will also try a different brand of filter since I heard Fram filters ( I am changing my oil in a few weeks) can cause pings and knocks.
    Maybe he can figure out what it is.
    As for the engine computer, I don't have the equipment to do that.
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
  • TNRabbit
    TNRabbit Posts: 2,168
    edited June 2010
    Fongolio wrote: »
    Kelvin
    I agree with Kelvin 100%. Sounds like a sensor issue or wiring between there & the engine computer if it just started all the sudden.
    The thought that an oil filter could cause ping/knock is preposterous. Fram filters suck because they are crappy quality. Mobil One (best!), Napa Gold, and Wix are the best filters I've ever used/dissected.
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • PerfectCreature
    edited June 2010
    Ok, so i should get this checked out by my mechanic then?
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
  • Jstas
    Jstas Posts: 14,985
    edited June 2010
    I've worked on enough 3.1's to know that that doesn't matter. The coolant temp sensor can be far enough out of whack to cause a problem yet still be within range to not throw a code and cause a light to be lit. Then again, not all codes will cause a light to be lit.
    A ping/knock is not necessarily a death sentence. Sometimes just a change in octane can make the difference. But, the carbon build up that is likely causing the problem to begin with is probably being caused by another problem. Get that problem fixed and your pinging should eventually go away as the carbon build up burns off.
    TNRabbit wrote: »
    That is not preposterous at all. The 3.0L Vulcan from Ford has a pressurized crank case and the oil pan gasket is prone to leaking. If it is leaking, you will get pinging in the combustion cycle and a leak down test will show a drop in compression which will cause your timing to be off.
    There are others that have similar problems. It's not common but it's not impossible for a bad seal on something like an oil filter to cause such a problem. With all of the issues that the 3.1L and the earlier 2.8L have I would not doubt that an oil filter issue could be a problem as well.
    Expert Moron Extraordinaire
    F1nut Posts: 51,763
    edited June 2010
    Push the accelerator all the way to the floor and hold it there, your problem will be fixed shortly.
  • PerfectCreature
    edited June 2010
    Maybe seafoam is the way to go.
    Seafoam it, clean out the inside, then add a higher octane gas...change the oil filter and see if that doesn't change it. If it doesn't it probably is a sensor and I should sell it to cut my losses?
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
  • Jstas
    Jstas Posts: 14,985
    edited June 2010
    I agree with seafoam if by seafoam you mean you are going to push it off a cliff, in to the sea and watch it sink beneath the foam while calling the insurance company on your cellphone and claiming the loss.
  • PerfectCreature
    edited June 2010
    Heh, I wouldn't get much for it they have it quoted at $560 worth.
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
    edited June 2010
    Jstas wrote: »
    There is already enough crap in the oceans. The last thing it needs is more oil right now.;):p:D
  • Jstas
    Jstas Posts: 14,985
    edited June 2010
    No, no oil. He said it all leaks out.
    pitdogg2 Posts: 27,045
    edited June 2010
    GM makes a fuel injector cleaner that you put into a pressurized container that feeds directly to the injectors. it will clean all carbon deposits from your injectors and valve area. I would ask your guy to try that. My auto dude used it on mine and it made one heck of a difference. cost me 50.00 in the end it was a bad injector but to rule out other possibilities it was the first step. Get away from Fram filters and use the right AC Delco for your car.
  • nadams
    nadams Posts: 5,877
    edited June 2010
    My old Ranger started pinging under load... chased it around for months before I got to the last possible thing it could be.... Replaced the Mass Airflow Sensor, and the pinging went away. A few hundred dollars later after trying Seafoam, plugs, wires, knock sensor, etc.
    The Seafoam is still a good idea from time to time. I let my truck ingest it from the brake booster vacuum line, straight out of the can, a little at a time. Makes a helluva smoke show, but it cleans it out good. Just make sure the vacuum line you choose feeds all the cylinders, not just one bank.
    Ludicrous gibs!
  • joeparaski
    joeparaski Posts: 1,865
    edited June 2010
    Exactly how do you know that it is engine "ping"? I've heard that word used to describe many things, and most were not engine ping at all. You mention that the noise is there at start up and when you rev it, and that it dies down after it warms up. Sounds to me like you are describing an exhaust manifold leak. Engine ping is usually apparent when the engine is under load (such a leaving from a stop light).
    Joe
    Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
    tonyb Posts: 33,072
    edited June 2010
    My thoughts exactly !!
  • sucks2beme
    sucks2beme Posts: 5,683
    edited June 2010
    This is the reason I'd like to get one of those newer scan tools that do
    streaming sensor data to a pc so you can see the marginal stuff.
    It's a shame that garages don't have a diagnostic dyno set up, so
    they can hook it up under load and see what's going wrong instead
    of throwing parts at everything.
  • DaveHo
    DaveHo Posts: 3,583
    edited June 2010
    Did this start suddenly? Maybe the timing chain/belt jumped a tooth?
    -Dave
  • mewisemagic
    mewisemagic Posts: 194
    edited June 2010
    rev limiter will kick in, won't do any damage
  • PerfectCreature
    edited June 2010
    Well, it is there at start up, it goes on for awhile, I can hear it when I rev it to go up a hill. I hear it when I am cruising through town at around 25 and push on the gas just a little bit to get up this tiny hill we have and you hear it no matter how much you push on the gas, its not that audible at higher speeds maybe due to road, and other sounds.
    Its like a pinging/clicking sound. Sometimes it will go into a deeper knocking sound.
    I will take it to my shop[ in town tomorrow maybe he can figure out whats wrong with it.
    I asked my wife about it she said its been there for awhile...I it was the first time I turned down my music at start up so...maybe that is why I heard it.
    Anyway, I'm a little worried about this pinging sound...
    Well, a lot worried.
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
  • joeparaski
    edited June 2010
    Let me ask you...do you know what a leaking exhaust manifold sounds like?
    Joe
  • shack
    shack Posts: 11,154
    edited June 2010
    If it is the car you talked about selling in an earlier thread...it is 15 years old with 126,000+ miles. From you description it sounds excactly like carbon buildup or weakened valve springs. That can easily be remedied by using a higher octane fuel. Try it and see if it helps. I would do that and spend a buck or two more at each fillup rather than spend much to get it fixed.
  • PerfectCreature
    edited June 2010
    I had my exuast replaced.
    Um, I have listened around and I really dont think thats what it is.
    Give me about 10 minutes, I'll post a video of it.
    Its uploading Right now. I went from the front to the back.
    I started the engine, then moved it around the engine bay, then moved it to the back maybe to hear something, then moved it back to the engine. Its about a minute...please take a look and let me know.
    By the way its at night time so it was quieter.
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
  • PerfectCreature
    edited June 2010
    <object width="640" height="505"><param name="movie" value="http://www.youtube-nocookie.com/v/hobwe9R-i8s&hl=en_US&fs=1&color1=0x3a3a3a&color2=0x999999"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube-nocookie.com/v/hobwe9R-i8s&hl=en_US&fs=1&color1=0x3a3a3a&color2=0x999999&quot; type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="505"></embed></object>
    There it is. Tell me what you think?
    Receiver
    Speakers
    Subwoofer
    Klipsch KSW-100
    Cables
    Alienware X51 R2
    PS4
  • joeparaski
    edited June 2010
    Having the exhaust replaced usually has nothing to do with the exhaust manifolds. I need you to answer this question with a 'yes' or a 'no'....do you know what an exhaust manifold gasket leak sounds like?
    I can't recall ever hearing an engine ping at idle after start up, which is why I think that what you are hearing is not the typical definition of an engine that "pings". If this engine actually pings at an idle, I doubt it would have any power to get out of its own way, let alone climb up a gentle hill. That would be one seriously sick engine, and the problem won't go away with liquid additives or premium fuel.
    Joe
    treitz3 Posts: 19,989
    edited June 2010
    That's not engine ping and knock. Sounds like metal hitting metal. That can't be good. Most likely comes and goes due to the metal expanding and contracting with temperature variations.
    As for what it is? I'm sure someone here will be able to diagnose that sound.
