What do you think about this speaker cable?
helipilotdoug
helipilotdoug Posts: 1,230
I'm thinking about buying some of this cable for the mains, SDA 2B's. They are going through the XO upgrade with RDO-198 tweets, mortite and dynamat tweaks. This cable is a mix of silver and copper. Thinking about using this for both regular and interconnect for the 2B's. What do you think about this cable?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=280450963797
Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com
Post edited by helipilotdoug on
  • Knucklehead
    Knucklehead Posts: 3,602
    edited June 2010
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • helipilotdoug
    edited June 2010
    Thanks Knucklehead! Did not realize there was another thread with this wire. From the sounds of it, this wire might not be the best route. I like what I saw on that other thread, and the links I found there. Appreciate the help. :)
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
  • chuckt62
    chuckt62 Posts: 33
    edited June 2010
    If you go for the 100% copper, you should consider the Furez wire from AV-Outlet also.
    I'm using their 12-2 wire and it's really good stuff. The 14-4 specs are a little better than the 4S11 and it's a little cheaper too.
  • helipilotdoug
    edited June 2010
    Hey thanks Chuckt62. I'm from Austin too :)
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
  • rmknotts123
    rmknotts123 Posts: 144
    edited June 2010
    speaking of speaker wire. Does the brand really matter or can you go to your local hardware store and purchase cheap stuff for 20 cents a foot?
    tonyb Posts: 33,072
    edited June 2010
    I think you should do a search for cables using the search function, all shall be revealed to you grasshopper.
  • LessisNevermore
    LessisNevermore Posts: 1,519
    edited June 2010
    tonyb wrote: »
    "bomb" word :D:D:D
    Yes, what Tony said. There's enough debate threads to keep you reading for weeks.
  • cstmar01
    cstmar01 Posts: 4,424
    edited June 2010
    Lasareath wrote: »
    I made mine even cheaper than that, I stole a few boxes of paper clips from one of my clients and I straightend each one and tied them together and it sounds so nice!
    Ha I stole all the coat hangers from a laundry mat and made mine.....nothing looks better than BEHRINGER amps with some computer speakers and coat hagers...oh and my source is a 80 dollar CD player....best ever!!!! :p
    heiney9 Posts: 25,432
    edited June 2010
    A bit overpriced if you ask me.
    $2.75/ft + $5.75 and .20c a foot for shipping
    16 feet would cost $53, while not outrageous Canare Star Quad is probably as good for less.
  • helipilotdoug
    edited June 2010
    Thanks Guys, I decided against getting that cable. Currently looking at all the info and will make a decision soon.
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
  • Imspun4u
    Imspun4u Posts: 48
    edited June 2010
    I definetely am not knocking any aftermarket wire's. Being an audiophile in the 80's I learned that the better equipment responded to costly wireing. I still have a pair of pricey 8ft Straightwire Maestro's from that decade. I ran across this article awhile back and decided to give it a try. Link: http://www.6moons.com/audioreviews/whitelightning/moonshine.html
    This wire recipe done as stated work's very very well. I did not put the end's on they suggested but simply tinned them with my soldering gun.
  • helipilotdoug
    edited June 2010
    Imspun4u wrote: »
    You know I've seen that before. I might just give that a try. The cost is low enough so that if I really don't like them, I won't feel too bad. :D
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
