What do you think about this speaker cable?
helipilotdoug
I'm thinking about buying some of this cable for the mains, SDA 2B's. They are going through the XO upgrade with RDO-198 tweets, mortite and dynamat tweaks. This cable is a mix of silver and copper. Thinking about using this for both regular and interconnect for the 2B's. What do you think about this cable?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=280450963797
Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
Thanks Knucklehead! Did not realize there was another thread with this wire. From the sounds of it, this wire might not be the best route. I like what I saw on that other thread, and the links I found there. Appreciate the help.
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com -
If you go for the 100% copper, you should consider the Furez wire from AV-Outlet also.
I'm using their 12-2 wire and it's really good stuff. The 14-4 specs are a little better than the 4S11 and it's a little cheaper too. -
Hey thanks Chuckt62. I'm from Austin too
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
speaking of speaker wire. Does the brand really matter or can you go to your local hardware store and purchase cheap stuff for 20 cents a foot?
rmknotts123 wrote: »speaking of speaker wire. Does the brand really matter or can you go to your local hardware store and purchase cheap stuff for 20 cents a foot?
I think you should do a search for cables using the search function, all shall be revealed to you grasshopper.HT SYSTEM-
lsi 9's -
"bomb" word
:D:D
Yes, what Tony said. There's enough debate threads to keep you reading for weeks. -
I made mine even cheaper than that, I stole a few boxes of paper clips from one of my clients and I straightend each one and tied them together and it sounds so nice!
Ha I stole all the coat hangers from a laundry mat and made mine.....nothing looks better than BEHRINGER amps with some computer speakers and coat hagers...oh and my source is a 80 dollar CD player....best ever!!!!
A bit overpriced if you ask me.
$2.75/ft + $5.75 and .20c a foot for shipping
16 feet would cost $53, while not outrageous Canare Star Quad is probably as good for less."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | Galion TS P75 Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Thanks Guys, I decided against getting that cable. Currently looking at all the info and will make a decision soon.Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
I definetely am not knocking any aftermarket wire's. Being an audiophile in the 80's I learned that the better equipment responded to costly wireing. I still have a pair of pricey 8ft Straightwire Maestro's from that decade. I ran across this article awhile back and decided to give it a try. Link: http://www.6moons.com/audioreviews/whitelightning/moonshine.html
This wire recipe done as stated work's very very well. I did not put the end's on they suggested but simply tinned them with my soldering gun. -
You know I've seen that before. I might just give that a try. The cost is low enough so that if I really don't like them, I won't feel too bad.
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
