digital coaxial audio vs optical audio
K-daugh
K-daugh Posts: 467
Aight boys and girls which is better coaxial or optical and why??????runnen a sony avr with monitor series spakers....any opinions will be appreciated ....any facts will be appreciated.....thanks
Budget 5.1 H.T. Set Up
HK avr 247 - Adcom GFA-7605:mrgreen::mrgreen: - Belkin PF60 Power Conditioner - Cs2 center channel - Monitor 60's fronts - Monitor 30's rears
Mirage Bps 150i powered sub - 40"Samsung LCD ln40c530 - Sony Blu Ray Player BDP-S370 - Comcast digital hd box(motorola dcx3400)
Monoprice Premium Interconnects Monoprice Ultra Slim HDMI w/Redmere:mrgreen: -Knukonceptz Kord 10 Gauge Speaker Wire - Nakamichi Banana Plugs
Custom Jumpers
Post edited by K-daugh on
«134
  • ben62670
    ben62670 Posts: 15,969
    edited June 2010
    Use the search feature;)
    Ben
  • K-daugh
    K-daugh Posts: 467
    edited June 2010
    what search feature im asking my fellow polkheads !!!!!!!
    Custom Jumpers
  • Conradicles
    Conradicles Posts: 6,357
    edited June 2010
    Searching is cool...
  • K-daugh
    K-daugh Posts: 467
    edited June 2010
    i like searchin too but at the moment i just wish someone would give me an answer
    Custom Jumpers
  • K-daugh
    K-daugh Posts: 467
    edited June 2010
    ok i did some searching and rendered no results.....some go one way some go the other...so what i wanna know is how do diehard polkie audiophiles go...
    Custom Jumpers
  • Knucklehead
    Knucklehead Posts: 3,602
    edited June 2010
    Im not die-hard, and most of these guys have forgotten more than I know.....but...I use both because its available.
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • K-daugh
    K-daugh Posts: 467
    edited June 2010
    why do i get the feeling that there is not a straight answer
    Custom Jumpers
  • Knucklehead
    edited June 2010
    Well, my answer is...I use optical on my cable box and coax on my DVD player because it dosent have optical.....to me on my stuff, one sounds just as good as the other.
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
  • zingo
    zingo Posts: 11,258
    edited June 2010
    You're not getting a straight answer because most of us don't want to re-hash that topic. I promise you there are threads upon threads on the topic if you search...
    http://www.polkaudio.com/forums/showthread.php?t=21006
    http://www.polkaudio.com/forums/showthread.php?t=100582&highlight=toslink
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited June 2010
    Basicly you should use optical if you have shiizty gear but use digital if you have good gear
  • polkfarmboy
    edited June 2010
    Yep but you gota have a good semi expensive cable
    edited June 2010
    As with most debates....they begin and continue. Most people 'here' prefer coax, I would say...but if you 'search' you'll see that some don't.
    You are quite right to be a little 'confused'. Welcome to the subjective world of 'listening'!
    Enjoy the 'debates'!
    cnh
  • K-daugh
    K-daugh Posts: 467
    edited June 2010
    Ok thanks guys intereting reads .....next question will I get beTter sound out of my dvd player hooking it up via dolby digital 5.1 or from the digital output which I have an option of a single coaxial or a single optical
    Custom Jumpers
  • K-daugh
    K-daugh Posts: 467
    edited June 2010
    My avr also has a similar digital jack with a coaxial or optical choice ....could I have the cable box hooked up and the dvd at the same time if I used optical for one and coaxial for the other.....obviously I wouldn't be using them at the same time ...which makes me think this could work....but my other option would be to have the dvd via 5.1 and the cable box via optical/coaxial......any thoughts
    Custom Jumpers
  • On3s&Z3r0s
    On3s&Z3r0s Posts: 1,013
    edited June 2010
    I've tried both from the same source (Toshiba CD's, HDCD's, DVD-Audio) going into a Benchmark DAC1 with various decent headphones (Senns & Audio Technica), and I can't hear a difference. Maybe it's my brain getting in the way because I don't know why I should be able to hear a difference. Both are digital, right? Coax is electrons carrying the digital signal and optical is photons, but at the end of the day the DAC is taking what should be the same 1's and 0's and making them into sound. So maybe I have dead ears, but I can't hear a difference.
    Coax is a lot more convenient and seems less fragile, so when I have that available, that's what I use.
    Is your last question about whether you should go analog from your DVD player (as in 5 RCA cables going to your AVR and one to your sub) versus digital? Depends on whether your AVR or DVD player has the better decoder. HDMI from the DVD to AVR is usually the preferred method if it's available.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited June 2010
    In my experience, there is absolutely no difference between coax/optical cables. I've tried several, and have never been able to tell any differences.
    I've heard plenty of differences in analog cables...but not digital.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • K-daugh
    K-daugh Posts: 467
    edited June 2010
    BlueFox wrote: »
    Primarily depends on which component has the better DAC, the DVD player, or the AVR.
    Well I believe both components have dolby digital and dts ......I dunno which is better.....and is 5.1 channel output supposed done with analog cables or coaxial ......also I'm looking for the best sound .....on my avr under the dvd input (only the sound, the video iS ran to the tv via component) there is rca inputs or two" digita"l inputs coaxial,or optical .....all under "dvd" there is also a spot on my avr for a 5.1 channel source , which my dvd does as well......and finally my cable box which I want to plug into either the optical or the coaxial.....so my question is how to I hook up both the cable box and the dvd and still get the dolby digital and dts or whatever .....what's the best way to do this
    My thoughts were to run the dvd coaxial to the avr and run the cable box optical to the avr ....my problem is the coaxial and optical jacks are both labeled dvd.....does this make any sense to anyone ????please help
    Custom Jumpers
  • Knucklehead
    edited June 2010
    Depending on your AVR, they may be "assignable".
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
  • acmf74
    acmf74 Posts: 937
    edited June 2010
    Just yesterday I did some swapping of cables between my Blu-Ray and AVR with some Digital Coaxs and Opticals. I really couldnt tell the difference between the two. I did leave the Optical in and it sounds awesome.
    The Optical was a Mono-price brand and the Coax was from my cable company.
  • TNRabbit
    TNRabbit Posts: 2,168
    edited June 2010
    FYI: Optical TOSLINK will not pass anything higher than 5.1~
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
    heiney9 Posts: 25,482
    edited June 2010
    K-daugh wrote: »
    This question has been asked over a dozen times. Do a search if you are really that interested.
    edited June 2010
    K-daugh wrote: »
    Beacuse there isn't a definitive answer. This is audio and much is subjective.
  • acmf74
    acmf74 Posts: 937
    edited June 2010
    heiney9 wrote: »
    Exactly....
  • WilliamM2
    WilliamM2 Posts: 4,808
    edited June 2010
    heiney9 wrote: »
    Yes there is. Most just refuse to accept it, preferring to cling to beliefs that have been disproven again and again.
    edited June 2010
    WilliamM2 wrote: »
    Giddy-up......................here we go. Another cable debate :rolleyes:. Sick and tired of them. Have fun guys.
  • acmf74
    acmf74 Posts: 937
    edited June 2010
    WilliamM2 wrote: »
  • cstmar01
    cstmar01 Posts: 4,424
    edited June 2010
    WilliamM2 wrote: »
    umm audio is subjective. what sounds good to me could sound like crap to another. this is not a cable debate thread, so I would suggest not derailing it to be one.
    To the OP honestly it doesn't make a difference in terms of digital cables. Use what is easiest for you and what you can find. They cost around the same for the cables (check mono price, ect) and should work fine in any application. I personally have used both but prefer coaxial as I don't like dealing with an opitical input and trying to get it in the little door ect, RCA plug is just easier IMO
  • On3s&Z3r0s
    edited June 2010
    K-daugh wrote: »
    This is a better question than the coax vs. optical one, cause it has the potential to make a bigger difference in how your system sounds once it is all hooked up.
    First thing, using a digital connection between your DVD and receiver will probably sound better than analog. Unless your DVD player is new and high-end (I'm guessing not based on the description of connection options) your AVR will probably do as good or better of a job with the decoding of the sound.
    Second, if the optical and digital coax inputs are both labeled DVD, then they probably aren't assignable, meaning you can use one or the other for the sound signal (in case your DVD player only had one or the other). But, you're not meant to use one for the DVD player and one for the Cable box.
    Third, the digital coax needs to be a 75-ohm cable terminated with RCA plugs. It's not the same as the RCA cables that carry an analog signal like for the front / center / surround channels. You need a special cable if you want to use that.
    If you want to post up the make and model numbers of your receiver and DVD player (and if someone is bored) they could probably help you make sense of the connection options better. Just knowing you have a Sony receiver isn't enough info to make a good recommendation of how to hook everything up.
  • K-daugh
    K-daugh Posts: 467
    edited June 2010
    If you want to post up the make and model numbers of your receiver and DVD player (and if someone is bored) they could probably help you make sense of the connection options better. Just knowing you have a Sony receiver isn't enough info to make a good recommendation of how to hook everything up.[/QUOTE]
    sony rceiver str de635
    Custom Jumpers
  • K-daugh
    K-daugh Posts: 467
    edited June 2010
    sony 5cd/dvd changer dvp-nc80v
    Custom Jumpers
