Upgrade to LSI25?
rmknotts123
rmknotts123 Posts: 144
edited June 2010 in Speakers
I currently have Polk Audio RTi A9's and a CSi A6 as my center. I have been thinking about upgrading to the LSI 25's. Is it worth the hassle or should I hold on to my A9's?
Post edited by rmknotts123 on
  • Bernal
    Bernal Posts: 991
    edited June 2010
    LSi 15
    01) DENON AVR-4308CI: Advanced 7.1 CH/5.1+2 CH/ 3.1+2+2 CH A/V Home Theater /MultiMedia Multi-Source/Zone Receiver with Networking and WiFi/170 watts x 7 channels
    02) SUNFIRE Grand Signature - Bob Carver's
    03) OPPO BDP-83SE Blu-ray Disc Player w/SACD & DVD-Audio
    04) OPPO DV-980H 1080p Up-Converting Universal DVD Player with HDMI and 7.1CH Audio
    05) DENON DVD-2500BTCI: Blu-ray Disc™ DVD/CD Digital Player/Transport
    06) HITACHI P55T501. 55" HD1080 Plasma HDTV
    07) POLKAUDIO LSiC (Center speaker)
    08) POLKAUDIO LSi15 LEFT (Front speaker)
    09) POLKAUDIO LSi15 RIGHT (Front speaker)
    10) POLKAUDIO LSiC Vertically (Surround speaker)
    11) POLKAUDIO LSiC Vertically (Surround speaker)
    12) POLKAUDIO LSif/x LEFT (Surround back speakers)
    13) POLKAUDIO LSif/x RIGHT (Surround back speakers)
    14) VELODYNE OPTIMUN SERIES 12"(High Output Digital EQ SubWoofer 2400W/1200WRMS)
    http://www.polkaudio.com/forums/showcase/view.php?userid=98096 (Not updated)
  • rmknotts123
    edited June 2010
    Bernal,
    Why the 15's over the 25's?
  • Frank840
    Frank840 Posts: 262
    edited June 2010
    I would Buy the 15's as well and the money you save could buy a subwoofer.
    - This your Bush?
    Pioneer Elite Sc-25
    Polk Lsic,15's,9's, PSW1000
  • bluecomet
    bluecomet Posts: 1,118
    edited June 2010
    If you can get a deal on the 25's buy them. They are outstanding.
    Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
    Yamaha RX-V2500 System, Carver A753 3 channel amp.
    Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
    Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9
  • rmknotts123
    edited June 2010
    I found someone who has the LSI 25's and is wanting to trade my A9's along with $300. Does this sound like a good deal?
  • Bernal
    Bernal Posts: 991
    edited June 2010
    Lsi15 is easier to configure.:)
    RTi A9 is 8 ohms.
    Lsi series is 4 ohms.
    If you are upgrading to the "LSI" series needs an external amplifier, 200 watts into 8 ohms.
  • bsoko2
    bsoko2 Posts: 1,449
    edited June 2010
    There is a pair of LSi15's for sale here in Bothell (near Seattle, WA) for $800 and so far, no takers.
    Bill
  • PSOVLSK
    PSOVLSK Posts: 5,422
    edited June 2010
    If you have the proper equipment to drive the LSi25's then I think it's a fair deal.
  • maximillian
    maximillian Posts: 2,149
    edited June 2010
    As already mentioned, you need a good amp to drive the LSi speakers. What equipment do you have?
    Also, make sure you listen to them before you trade. You may not like the laid back sound of the LSi series compared to the more forward RTi A9's. Even the LSi's are considered a "better" speaker, many people prefer the RTi's over them. If possible, even do a side-by-side before you decide.
  • chargerman426
    chargerman426 Posts: 419
    edited June 2010
    Bernal wrote: »
    RTi A9 is 8 ohms.
    Bernal I have seen this statement of "you need an amp that does 200 watts into 8 ohms" before in regards to the LSi line. My question to you is if the LSi or 4ohms then what the amp does in 8 isn't relevant IMO. The more relevant number is what it does into 4. Please don't take it as I'm getting on you I'm not I just have seen this else were and I'm wondering why people are making that statement.
    If life had more tubes it would be a lot smoother.
  • chargerman426
    edited June 2010
    rmknotts It depends on 2 things.
    1. Is this going to be a many music or HT rig
    2. How much money are you willing to invest.
  • bld
    bld Posts: 25
    edited June 2010
    My opinion is to get the 15's,put the rest of the money into an amp instead of having them combined in a speaker.More choices later if you want to make changes.
    nad t175 processor
    Sunfire TGA 7401 amp
    LSi15 front
    LSi center
    LSI 9 surround
    dual sunfire hrs 12 subs
    LG bd 390 blueray
    Sonos
  • Bernal
    Bernal Posts: 991
    edited June 2010
    Easy to explain:
    Amplifier features: in 8 ohm speakers and its setting in 4 ohm speakers
  • rmknotts123
    edited June 2010
    Equipment wise I have a Yamaha RX-V1065. Amp wise I do not have a home theater amp, but I do have a Crown XLS 402 amplifier that runs 4 ohms at 450 watts max into 2 channels. The Hz and DB factor would be no issue as it runs even with the LSI's. I have had it hooked up before through my preamps to my RTI A9's. I had the RTI A9's single wired with a split switch towards the end (like a light switch) to where I could bypass the preamp and have the signal sent through the regular speaker terminals. I would run 2 channel stereo stereo through the amp, and have HT ran though the speaker terminals. This may sound stupid to a lot of you, but the amp produces clean power and sound with extremely low distortion. As for the switch. The receiver does not recognize the pre-amps unless the "light switch" is set to that specification. I have a little background in pro audio, spliced a few cables, and put together a nice 2 channel amplified system that could be ran either through the speaker terminals or the pre outs. I like to use my system as a 7.1 or 7.2 for HT and 2 channel for Music.
  • chargerman426
    edited June 2010
    Bernal wrote: »
    Easy to explain:
    That amp has nothing to do with discussion so that really didn't help your statement. The fact that I'm trying to get at is the LSi are 4ohm speakers and an amps 8ohm spec doesn't have any bearing on what its going to be into 4.
    The OP has a pro amp so he should be fine with the 4ohm speakers.
    rmknotts123 please remember max/peak watts are not as important as RMS numbers are. Peak number are very misleading. Companies like Sony will use peak number to make there crappy AVRs look like they put out as much power as a dedicated amp.
  • rmknotts123
    edited June 2010
    Chargerman,
    Yes I know the max power differs from the RMS power. Rms on my crown amp is 300, which is a tad over the 250 that the LSI's need, but with the proper adjustment will be no issue.
  • rmknotts123
    edited June 2010
    I do like how Bernal butchers the 8 ohm and 4 ohm issue however.
  • rmknotts123
    edited June 2010
    Chargerman,
    I do like how the home theaters in a box claim to have so much power. Phillips, sony, LG, rca, and samsung just to name a few. I went into best buy yesterday to look at a new washer and dryer and decided to stop and peak through the home theater section (which sucks I might add), and the salesman tried to sell me a LG bluray surround that was 1000 watts. I kind of laughed on the inside and went back to the washers.
  • Jetmaker737
    Jetmaker737 Posts: 1,144
    edited June 2010
    Well, why don't you two noobs educate us :rolleyes:
    edited June 2010
    Chill out, no need to bait an arguement when one doesn't exist.
    { Comming from me? Dear Lord, I've gone to the dark side.}
  • rmknotts123
    edited June 2010
    Noob this.
  • bld
    bld Posts: 25
    edited June 2010
    I think what bernal is trying to say is that in the sunfire the wattage output doubles everytime you halve your impedance.
    nad t175 processor
    LSi15 front
    LSi center
    LSI 9 surround
    LG bd 390 blueray
    Sonos
  • Bernal
    Bernal Posts: 991
    edited June 2010
    Ok, well the person who wanted to trade me his LSi25's decided he wanted to keep them and backed out.
    I know I'm not quite to 100 posts yet and I know this isn't the selling forum, but anyone interested in purchasing 2 RTi A9's (about a year old), 2 TSi 300's (brand new in boxes), 2 Rti A3's (around 6 months old), 1 CSi A6 (around 6 months old), 1 DSW Micropro 1000 (4 months old). All speakers are cherry in color except the DSW, which is black. The TSi 300's I purchased as zone 2 speakers, but have decided not to run them to the back porch. I would be willing to deliver the speakers within a 2 hundred mile radius from zip code 47304 (Muncie, IN). Asking prices vary depending on speakers wanted. I will sell the A9's, A6, A3's, and DSW as a package if desired to have a nice front speaker set up with the A3's as rears in a 5.1 setup. If interested give me your email and I will send you pictures. I also have the speakers on craigslist, but since this is a polk forum I assume you know more about the speakers than most nay sayers on craigslist.
  • cstmar01
    cstmar01 Posts: 4,424
    edited June 2010
    you were informed before that you can't sell in other areas. You even acknowledge this in your post. My recommendations is not to post like this again as many people will not like what you are doing.
    Also in regards to what Bernal was saying he recommended the Sunfire if you were to get the LSi25's as its a very good amp to drive them. He is correct that it is a good amp, and will preform very well for the application it would be in. Also normally it is not recommended to use a pro audio amp that is made for DJ or gigs to be used in home audio as they commonly don't mix well. Bernal made a great suggestion and would recommend looking at what he said. The sunfire will double down in power, which is a good thing for an amp to be able to do. Also it has a very low noise floor which is good for home audio as well.
  • Jetmaker737
    edited June 2010
    FYI... I wasn't hating or baiting an argument. But these two guys with a combined 30-something posts were trashing on Bernal instead of maybe taking ten seconds to understand what he was trying to tell them.
  • chargerman426
    edited June 2010
    You kind of were/still are baiting. This thread has gone down hill and theres nothing left to talk about. Just because you have more post doesnt mean they were usefully. Have a nice day. :)
  • Jetmaker737
    edited June 2010
    I disagree. And your previous posts in this thread show that you just don't get it. Here, let me explain...
    What Mr. Bernal stated was that the OP should look for an amp with 200 Watts minimum into 8 Ohms. This is an accepted rule of thumb for LSi speakers (sometimes 250W is stated). It is based on the fact that you need at least 400 Watts to drive the 4 Ohm LSi's. Most always you can find the 8 Ohm rating of an amp, but maybe not the 4 Ohm rating. Most good quality amps will double the Wattage from 4 to 8 Ohms. Therefore the recommendation for the 8 Ohm rating.
    I'd expect that new members of a forum looking for advice (or commenting on advice) from existing members would refrain from derogatory comments before trying to understand the advice given.
    ... now I can't believe I wasted so much time typing this up, but oh well.
  • nguyendot
    nguyendot Posts: 3,594
    edited June 2010
    Guys, the point has been made, let it go.
    Main Surround -
    edited June 2010
    I hear ya, but take a deep breath, watch a porno or something,it's not worth it.
